Great pricing on KYB Monomax shocks
You're right about them expanding rapidly. The front's were the ones that took a little bit of finesse and quickness. I had to compress them by hand and quickly snake them in before they expanded. Took me a few tries on one side, but after that I was able to do the other side quickly without any hassle.
KYB vs Old Man Emu
How are the KYB compared to Old Man Emu for our Monty's?
Im content & pleased with OME on my rig, just curious?
Thanks in advance......
Cheaper, more readily available (pep boys, napa, etc.) and probably works just as well. Plus KYB are the Original Equipment Manufacturer for the original Mitsu shocks. The fact that my adjustable shocks are still working after 17 years and over 200k miles has earned my continued trust in KYB.
Did you have the factory adjustable shocks previously? And if so, what did you do to block off or delete that system?
All you do is take off the small bolts holding the motors to adjust the shocks and cable tie them up and out of the way.
A wee trick i've learnt for replacing shocks is to get the fattest person you know to compress them,and tie them in their compressed state with some of the orange string used in bale machines,put in the bottom bolt in,and cut the twine,allowing the top to shoot up through the hole. And if you find the top nuts hard to get out without the shock spinning hold the body with a filter wrench.
I've KYBs on the front of mine,and I find them nice,not too hard and not too soft
Hey Limp_Noodle.... question: how was your experience ordering these shocks via Just Suspension at Amazon.com? I checked out their website, and Better Business Bureau page... they have terrible reviews all over the place.
Did you receive the correct items? Any parts missing? Any shipping delays etc?
Just want to make sure there were no issues, before ordering.
Other than less than desirable packaging I got my shocks without problems. All the pieces were there and they weren't damaged. Shipping was quick as well. I ordered them on Sunday and received them on Friday.
All they did as far as packaging they just taped the boxes together. I would have preferred they at least packed them in a box with some packaging materials, but I can't complain since they came in just fine.
I bought through Amazon since they've always been good with customer service if I had any problems.
They are both monotube shocks, so ride quality should be about the same. I know in the autocross world the kyb AGX is one of the best shocks you can buy for the money and last very well.
Good info. What about the rears, any tips? They look pretty easy. Do you have to take the rear wheels off?
I just did these, and the rears are super-easy. I didn't remove the rear wheels or even jack the back of the truck up. Just left it on the ground and rolled underneath, and reached over the top of the tires. Had to go buy a pair of 24mm wrenches, though (Home Depot, $5 each for Husky's), to get the bottom shock bolts off.
The fronts were a bit harder, but not terrible. I took the wheels off up front, doubt you could leave 'em on.
The hardest part of the whole job was compressing the new Monomax's all the way down, then very quickly whipping them into place, lining them up and pushing bolts into place to keep them lined up before tightening everything up.
I rotated my tires, and upon test driving the Monty, the rear suspension felt odd, like I was porpoising down the road. I knew the original shocks were tired (185k miles), so I bought new KYB Monomax's at the local Autozone ($150 for the rear pair), hoisted up the truck, and started to remove the existing rear shocks. I got the topnut off the left rear shock tower, and much to my surprise, the shock dropped down to the ground in several pieces! It was absolutely destroyed. Looks like the spindle went through the side of the outer housing after shearing off ending up who know's where. It's amazing how well the truck road on just springs! New shocks went in easily, and the porpoising went away, now it's firm and controlled again. Ready for the Death Valley washboard in a couple days!
BTW, I did not remove the rear tires, but I did apply liberal amounts of PB Blaster to the nuts prior to tackling the job. I struggled to compress the shocks manually, so I opted to hoist the truck up into full droop (with the swaybar still connected), and in that position, everything lined up perfectly.
In re-reading this thread, I have a few possible answers to earlier questions:
1. According to KYB, the Monomax's are a heavier duty shock than the Gas-A-Just shocks, and are specifically built for SUV's or light trucks and off road use. They are also about $20 more expensive per shock.
2. They are a fairly ugly red color
3. They ship will all the hardware, except the bottom bolt (which is a high quality factory Grade 8 bolt and showed no corrosion or wear on mine, and its a PNW truck).
4. No instructions are included, but it's not really necessary, except may to explain the zipties that come with them? I suppose you could use the ZipTies to keep the shock compressed, but I am unclear as to HOW to do that...It was easy to lift the truck instead.
5. You need a 14mm wrench, and a 14mm socket/ratchet to remove the top nuts
6. You need a 24mm wrench or socket/ratchet and a big monkey wrench for the bottom bolts. I had to apply considerable effort to loosen this bottom bolt, and I was using a 16" long ratchet and a similar sized adjustable wrench. Once it broke free, I was able to undo all the bolts by hand. They turned easily after the initial hold was passed.
7. Safety! If you lift the truck, you need to hoist it all the way up so the rear wheels are off the ground (to extend the shocks). I have tall jack stands that I placed under the frame once lifted. Never rely on the jack to keep the truck up!
8. Once installed, the Monomax's definitely felt stiffer than the old, tired, worn out, and Broken (!) OEM shocks. However, they were really well dampened. I blasted through a bunch of speed bumps, and then through a bumpy dirt field, and the rear end was totally smooth through it all, and behaved really well. I wish I had the money to do the front end now.
Jlbeats
