Utility trailer (removeable camper mod)
Nice! That looks to be a good, solid solution. I'm looking for a low profile option for my camper. I'll have to see if I could get those to work for may application.
As you can see, I have gotten more done. But I am a lot further than this, it got dark on me before I could get pictures. The roof is now plywood. The front wall is totally enclosed now, just got to make some adjustments to the angle piece, and it will be done. I trimmed out the roof line in 1x2's too, so there is a small over hang, hopefully water will not find it's way in...
Tomorrow's list of things to accomplish.
1- Frame & plywood a door
2- Make some adjustments to the angled plywood piece
3- Finish cutting the wood for the trailer rail enclosure
After all that, it will be tape & glue process for all the seams... Yippy :clapsmile
It's not as heavy as I thought. I am still able to pick up the tongue of the trailer and move it around with no problems
looking forward to your progress. thinking of doing something similar. what size is your trailer and what is the axle rated for? tks
No windows?
Yes, just haven't gotten them yet.. I wanted to get the major fabrication done first, plus I'm gonna have to special order the size windows I want, from Home Depot. They don't have them in store
Updates... Fabrication pretty much complete
This is what I made to screw the sides onto the trailer under the rails
Taking it for a test run
That's good to hear on the weight. How how do you plan to side it?
No siding... I'm going to paint it with about 2-3 coats of Rust-Oleum's PROFESSIONAL High Performance Protective Enamel
I have used this paint a lot and it holds up well... It's an Oil-Based paint.
I'm thinking about painting the sides safety yellow, and white on the top to match my FJ... What's y'alls thoughts?
Jlbeats
