2015 Toyota 4Runner Trail Premium w/KDKDSS Overland Build. Done....for now. ;)
CuStOm
Zero Rub without the spacers. With the spacers I had to use a heat gun and move the fender liner a little on the front inside. Only rubbed there at full lock.
Spacers were added to restore the inch of track width that was lost when lifting the IFS. It made a very noticeable improvement in stability.
I am not the type to track mileage and they were put on at about 400 miles so I barely had more than one tank of gas through it before swapping things out.
Dalko43
Nice looking truck! Just needs a little mud and brush striping to "officially" break it in...
Also cool idea on the Hi-lift jack placement! I've been wondering myself where to place a hi-lift jack, and like the idea of keeping that weight low, rather than high up on the roof. Only question is how well will that hold up going through rough terrain and water, and how well can you get to it if the rear bumper gets submerged? Like the idea and would love to see some thorough "field testing."
CuStOm
It's gotten used several times, I just take care of my stuff. I buffed pinstripes out for an hour last week just before this picture. :)
photo nomad
I'm just curious about the width of your Baja Rack utility rack. On their site it says the rack is only 46" wide, but the James Baroud Evasion Evo is 55" wide. Not sure if its just me, but it does not look like the RTT is hanging over 4.5" on each side of the rack?
CuStOm
It definitely is. It's somewhat of an optical illusion with the sides of the 4runner at a negative angle. It works just fine.
photo nomad
Good to know. Thanks! Did they have to make you a custom awning mount to extend it a little further out away from the rack and RTT?
ncflyer
Nice Start on the 4runner. I've got an unlimited rubicon and you folks are making it hard not to consider a changeover! On the ladder. Does it swivel at the top or do you lose the ability to raise the rear while it's on? Thanks.
Houie
