Fire Extinguisher?
Ducky's Dad
Size does matter. Looking at 2.5 pound units (because that is what I have and because it seems the best physical fit in a lot of vehicles) and getting the ratings from the Amerex catalog, here is what you find:
Halotron I 2 B-C
Halon 1211 5 B-C
Carbon Dioxide 2 B-C
ABC Dry Chemical 1 A: 10 B-C
Regular Dry Chemical 10 B-C
Purple K 10 B-C
Wide swings in effectiveness on different fire types, all from the same size can. Choose carefully. Bigger is better if you have the space and can get to it quickly.
landsharkman
FWIW, I'd personally leave the halguard and only take the powder. It'll save confusion, especially if you're in a position of where you're telling someone to grab the extinguisher. The time you'll take trying to figure out which class of fire you're trying to put out in the engine compartment could be used applying an extinguisher that works for all of the common fires you'll deal with on a vehicle (unless you drive an old VW, but that's a different animal)[/QUOTE]
I figure I will use the Halguard first, they are mounted in a way that they are easy to get to and only use the powder if it flares up
Inyo_man
Don't piss down my back and tell me it's raining.
I did 23 years in the fire service, so I speak with a little experience.
A 5lb Amerex ABC extinguisher will do for most things. if you have a camper or toy hauler, then I would get a 10lb. Larger than that becomes cumbersome, and if you cant put it out with 10lbs of ABC powder, you need to get everyone away and call the fire department.
And Halon is no good for most fires in cars. Doesnt work for class A or B fires and unless you disconnect the battery first, wont work on class C fires.
Halon gas works on the principle of blocking the oxygen from feeding the fire. It doesnt remove heat like water or CO2, and it doesnt coat and block like dry powder. As soon as the halon gas is dissapated or blown away by the wind outside, the heat and burining material is free to re-ignite.
Places like computer rooms use Halon because its a closed space and when the system activates, it shuts down the HVAC system and floods the room. Same with the US Navy (who is the largest user of Halon in the world) Seal the compartment and flood it with Halon, fire goes out, and then wait till it cools down before you open the hatch.
if you have a fire in your car, the last thing you will think about is damage to your sterio. You will want to put the fire out quickly and effectively to insure it doesn't flare up again in 15 seconds when the Halon disapates.
Well said...
I've carried a five pound ABC for years.
Remember to recharge extinguishers annually.
emtmark
Austere Medical Provider
Having a car burn down around me left a decidedly over kill theme of suppression. Two 10lb dry chem and a 5 gallon piss pump for camp chores.
patoz
I am a DoD District Fire Chief/EMT, with 35 years' experience and now retired, so I also have some expertise in this area. NYresQ's statement is right on the mark, and I concur completely. There are only a few things I would like to add...
1. Halon is useless fighting a vehicle fire! If you use it for a stove fire in an RV, you better have the windows and doors open, then dump it and run.
2. ABC is the extinguisher of choice for vehicles, but carry two of them (Murphy's Law), either the same size (5-10 lb.) or one smaller (2.5-5 lb.) and one larger (5-10 lb.) size. IMO, the 2.5 lb. size is almost useless, because you have no reserve capability. One shot and it's gone, so I hope the fire doesn't flare back up. If you have the room to carry only one, go with a least a 5 lb. model. Just remember how far away the closest Fire Department is when your truck catches on fire on the lonely mountain road.
3. PKP is good for vehicle fires, but it is highly corrosive when it gets wet.
4. Any kind of powder does pack down over time, especially if subjected to vibration also. Our procedure for any Dry Powder Extinguisher carried on a vehicle was, once a month we would hold the extinguisher upside down and tap the sides and bottom with a rubber mallet, starting at the neck on the cylinder (which is now upside down) and working around and up towards the bottom of the cylinder, which is now facing up. This will cause the powder to fall toward the neck and 'fluff' itself up.
5. CO2 does have a cooling effect right out of the horn, but is really only effective in an enclosed space. It dissipates almost immediately, and has no lasting effects to prevent reflash.
6. Don't forget to check the seal on your extinguisher. It holds the safety pin in place on some extinguishers, and can allow the pin to fall out if broken. Having a 10 lb. dry powder extinguisher slide forward in the trunk of 1968 Mustang and wedge in the 'open' position will ruin your day. Don't ask me how I know!
7. How many of you have Magnesium or Titanium wheels, engine blocks or manifolds, or other parts on your rigs? These combustible metals will burn with an intensity of an arc welder, and common extinguishing agents will not put them out.
The only way to extinguish a combustible metal fire involving alkali earth metals and transitional metals is to provide an inert atmosphere of argon or helium, which in most fire situations is impracticable. Applying other agents will contain the fire until the metal has oxidized to a point at which heat production is reduced below the ignition point.
Putting water on it is like putting gasoline on a campfire! For every gallon of water you apply to a combustible metal fire, there is a potential release of hydrogen equivalent in energy to 0.43 gallons of gasoline. Every 100 gallons per minute of fire flow on a combustible metal fire provides the equivalent of 43 gallons of gasoline. You are also applying a significant amount of oxygen, which is also released to assist the burning.
You can read more here: http://www.fireengineering.com/arti...oper-handling-of-combustible-metal-fires.html
Back in the early 70's, we responded to a vehicle fire which turned out to be one of those VW dune buggies with a fiberglass body and magnesium rims, custom engine components, and even the fuel tank which looked like a beer keg. We dumped everything we had on our Fire Engine on it, and it still burned to the ground...literally. There was nothing left but the frame and a few other steel components.
Well guys, that's my story and I'm sticking to it. I hope it helps in some way.
Jason911
Where were you stationed? I did some contract work for the DOD for a number of years, specifically for the fire services(DOD and CES, Air Force mostly) and I visited multiple bases around the US. Maybe I bumped into you.
patoz
I worked at Naval Air Station Pensacola from 1973 to 2003.
Jason911
Thats answers that question. Nope, didn't bump into you. Only stuff I did for the Navy was train the trainer. And then everything was shipped to Africa.
I worked with Ultra High Pressure firefighting (UHP).
patoz
Oh well, still it's good to run into other people who work(ed) in the Emergency Services field. :)
Jason911
Indeed it is!
On a separate note, for small fires and anyone not wanting to mess with dry chem or purple K fire extinguishers, you can check out this company I found in my travels. VERY very spendie, and completely proprietary, but really works. Its non-corrosive, clean and has a unlimited lifetime warranty + you can use just a little and then put it back in storage/service WITHOUT having to refill. Hugely popular in the Agriculture community. No affiliation.
http://www.ake.com
patoz
Jason, this is interesting. Have you seen one of these operate in person? I just watched the one video so far, but I'm going to pursue this further.
Jason911
Yes I have - hence the reason I posted it. It just works, and works VERY well. The demo I go was just short of unbelievable - I actually forwarded the company to my former colleague who now works for the US Air Force Research Lab. Last I heard was a full consideration for flight line wheeled extinguishers replacement.
CharlieGreenT
