Love Being In The Dog House (trailer)
Sb_Moto
What TMeyes1 is saying is that he will not always have a garden hose. He may be relying on using Jerry cans or something similar to fill the tank. In this case he cannot easily pressure fill.
JamesC
Awesome. Are those 4runner rims? I wanted a lug pattern that matched my LC, but cannot find hubs that are 5x150 so I settled on the Toyota 6x5.5 since I have extra rims from when I had my Tacoma.
I had the same problem and used these on the m1101 for 6x5.5 to 5 x 150: http://www.amazon.com/gp/product/B009N3JTQQ?psc=1&redirect=true&ref_=od_aui_detailpages00
Many thousands of miles but of course opinions differ on adaptors. These are very well made in this conversion fitment and I don't feel they are much of a compromise considering the spares benefits :)
T-Rey1
Solar Mount
Finally got the solar panel mounted to the roof rack. Used some 1 1/4" ID square tube and some 1" OD square tube to make the cross bars to fit over the existing bars. The new bars are adjustable to slide left or right. They will only be supporting the panel. Drilled holes in the panel side and the square tube and used hitch pins to keep everything together. I also made an arm to hold the panel at 45 degrees when needed.
T-Rey1
Rock Lights
Added some lighting to the bottom of the trailer. Helps out in camp to see around the trailer without lighting up the whole camp. Not bad for $20 from Wal-Mart
T-Rey1
Kitchen Slide
When I bought the trailer I had a shelf on a slide in the rear kitchen area. I had removed the shelf and was going to make a drawer system, but did not want to get into that so I had another idea. The slides it came with were 16" slides and would not have enough to come out that far. I already had a set of 18" slides so I used those and a larger piece of birch wood for the shelf. It holds my camp kitchen well with enough room to open it up when the slide is out.
T-Rey1
Outside Lights
I found some lights for the outside of the trailer to mount by the doors. These lights are solar powered and are always on, but very dim until motion detected. I did not think they would be so bright, but they work pretty well for the price. These lights have a double sided tape or hardware to screw to a wall.
http://www.amazon.com/Swiftly-Brigh...&redirect=true&ref_=oh_aui_detailpage_o07_s00
Dim mode.
Full light. The motion detect is very good as far as range
T-Rey1
Shelf
Had an extra piece of birch that was used as a slide out in the rear, but since I removed it I need to find somewhere else for it. I used a set of folding shelf slides and mounted it to the front interior of the trailer. worked out pretty well. Hinges lock in the up position and are spring loaded so in the down position it does not swing out.
T-Rey1
Slide Storage
Was wandering around Lowes the other day and came across some kitchen cabinet slides that were on clearance. bought one and it was a perfect fit in the back next to the kitchen slide out. this one slides into the sleeping compartment. Was a perfect fit.
ilciclista
