Homemade Pelican Area Lighting System
Seeker247
Has anyone tried to create a DIY version of one of the pelican area lighting units? I love the idea but their prices are way too much. I've been thinking of possibly using a Rigid Q series diffused light along with some sort of battery system in a pelican type case. Any ideas would be greatly appreciated. Just trying to get some input before I start shopping around for components.
screwball48
For a while now I have been using a lithium jump pack and led work light as emergency lighting for power outages.
http://www.walmart.com/ip/Whistler-Jump-Go-Portable-Jumpstart-and-Power-Supply/47722680
Utilitech Pro 1-Light 10-Watt LED Portable Work Light http://www.lowes.com/pd_580828-43921-MPL1004-LED10K840_?productId=50196411
Both items are dual use. The lithium pack has been used to power the light as well as jump start a car and my lawn mower. The led light is 12v and 110 so it works at home and away.
kj4vyi
Sweet !! this is awesome gonna have to get one of these up and running. I think I have most of these items laying around the shop.
Thanks for the tip
Chad
Seeker247
The quick fist idea is a lot simpler than what i was thinking. I was trying to find a way to modify a pelican case to accept a pole, like possibly a slot in which the pole slides into. But the quick fists definitely make it simpler and more versatile.
Thanks
kj4vyi
I had these 3D printed up a while back for a ham radio antenna. There were about 5-6 different versions to accept with square or round antenna elements that mount to an aluminum boom ( 1") I would think i could mount these to the side of a pelican box or any box of that matter as long as the box has weight and girth to hold up the pole with the light
I found them on the SATNOGS site when they first came out - -https://satnogs.org/documentation/hardware/
So if you have access to a 3d printer you could print it out
you could also look on thingaverse and see if there is something that would work or design your own for a pole holder -- this might work http://www.thingiverse.com/thing:753409
Chad
guapstyle
