2000 Tundra "catch and release" expo rig
Lift is done. Tires/wheels done. Toyo Open Country A/T2. 34x11x17. Love the stance and look. Just what I was after.
Minor frame rubbing at full turn. It grazes the front lower valance on the bumper as well, but that will be cured with the plate bumper I will build.
Had an issue with the small oring on the back of the water pump that connects to the heater line.
It got torn when I installed it and had a very subtle coolant leak. So, i tore off the thermostat housing and was able to get it pulled and a new one installed. No leaks.
did you put spacers on the rear as well, or just front? /curious Like the look of the 4Runner wheels!
That looks great!
Is this the same bumper that Addicted Offroad sells for the Tundra/Sequoia?
If so, could you post some additional pictures of how the lower edge of the bumper transitions to the front diff area? I'd like to see how it's covered/protected.
HButton
