I'm in the market for a drawer system for my 2004 F250 Super Duty (with the supercab) which has an A.R.E. Shell on it.
I originally looked at the TruckVault brand, but after seeing the price and having a heart attack, I was going to custom build one but I have too many projects going as it is. Also, I'm getting older and have chronic lower back problems that are getting worse every day, so I'm now looking for something I can just drop in and go.
About eight months ago, after reading everything I could about the Decked System, I thought I had found the answer. I went down to my local dealer with the intentions of purchasing one, but after looking at their display model, I left quite disappointed.
The biggest problem I found with it was, there is a lot of wasted space!
1. Every wall on it is thick and bulky to give it strength.
2. The drawers only open 2/3 of the way, with almost no access to the last third of the drawer. This is a major drawback!
3. The sides of the drawers are tapered and narrower at the bottom, which means tool boxes, tackle boxes, etc. will not sit fully against the side walls creating more wasted space. I do see a custom fitted box is now available to fit the drawers, but that means all new toolboxes must be purchased.
4. The lock mechanism takes up almost 6" at the front of the drawer wasting more space.
5. The roller mechanism and tracks take up quite a bit of space also, including another 4"- 6" right down the middle.
But, on a good note!
1. The thing is well build using very good materials.
2. It is supposed to be weatherproof, however I can't verify that since I don't own one.
3. Several accessories are available for it such as, trays, dividers, and tie down points.
4. Easy to install and doesn't require modification of your vehicle. This is a major plus!
5. I suspect it is lighter weight than an all metal or metal/wood hybrid product.
6. And most importantly, it's made in the good old USA!
Right now, I feel like I would lose too much space with the Decked System, and considering what it cost, that's not acceptable. I have almost decided to just install a bed slide, and that way I can put what I need on it and where, but that doesn't solve the problem of concealment or security.
However, with all of that being said I would be willing to test one of the Decked Systems to see if my first observations and opinions are wrong. I learned a long time ago, no matter how much you read, hear, or look at something, you can't really develop a good sense of its quality or capabilities until you actually use it in the real world. If my original opinion turns out to be wrong, I would probably purchase one because I need something now. It's getting just too hard to crawl in and out of the back of that truck.
In addition to a couple of pretty complete tool boxes, I also carry off-road recovery tools, roadside emergency tools and supplies, medical gear (EMT), and survival tools and supplies, etc. Once a Firefighter, always a Firefighter! I'm also in the process of building an off-road camper, and am constantly transporting supplies and components and going in and out of the back to retrieve items.
The truck is my daily driver and is also used for working, camping, shooting, and general purpose hauling.
Update: I just found
this thread, in the Storage Solutions section, so I copied this post to there also.
