Trailer floors?
Kiriesh
Finally have time to work on my trailer project so I need to (literally) start from the ground up. Currently I have a frame in progress and I'm planning on using a fiberglass m416 kit like seen here:
http://dinoot.com/models/m-series.html
but that leaves a major question, what should I use for my floor of the trailer? I've put some thought into it, wood seems to be common but I worry about the long-term durability. Obviously steel or aluminum sheet would hold up considerably better but at the cost of a considerable weight gain. Anyone have insight on what they used and why?
1store
Banned
What is your long term use .Will you have a cover .Will it be in doors .When not in used. When I got my different kit there was a guy out of Palo alto that used a aluminum floor. One of his concern was the moisture between the steel and aluminum . I'll see if I can find his email
PCO6
I have a steel floor and box frame with aluminum walls. I use 2" wide pipe wrap between the 2 materials where they overlap and have no problems with moisture or corrosion.
Places like Home Depot, Lowe's, etc. sell it ...
http://guide.alibaba.com/shop/william-h-harvey-014130-pipe-wrap-tape-2-x100-pipe-tape_35166820.html
PCO6
^^^ Nice thing too is that one side is adhesive. Just peel off the paper and stick it to one of the 2 materials before you attach them. It's also easy to cut if you want narrower width pieces. ... and no mess compared to caulking!
M35A2
Tinkerer
Stainless steel to aluminum is a no-no. You will get galvanic corrosion and the aluminum is sacrificed.
RocknLJ
My Bear Trailersports off road trailer is a fully welded steel trailer with diamond plate floor and sides. I built a metal frame out of 3/4" square tube and made a top with hinged doors out of plywood. Total trailer weight is under 900 lbs (without RTT) and tows like a dream. The steel floor is durable but I have been thinking of how to add a rubberized mat to reduce the harsh ride for the cargo.
compactcamping
Kiriesh, plywood is the most common used in Dinoots. I seal my plywood floors with Durabak roll-on bed liner, seals it watertight. Have had customers make M-Series floors out of steel, but don't believe anyone has done an aluminum one yet.
M-Series Dinoot with Durabak sealed plywood floor
jscherb
The floor of this Dinoot is 3/4" plywood. It was first painted with epoxy primer, then shot with Raptor bed liner color matched to the exterior of the trailer.
Everything in primer before the bedliner and final paint on the tub:
Mitch Bears
