Hauling A Motorcycle With A Truck Camper
Nope
KISS method, always.
Mechanical boat winch.
And it weighs less than 50 lbs.
With the bike loaded Ill sneak under 300#
Thanks.
With any luck Ill be able to get back to that project soon
Sidetracked with other people projects at the moment.
I may have to barrow your design. With my rear winch it could double as a rear door platform.
The gears are a grindin.........
Here is a pic of what not to do! Carried my Vstrom up north last summer. Carrier took it like a champ but there was a major problem loading and unloading. Was a 2 man job getting it up there and a 4 man job getting it off!
Here's an update on mine.
Came together pretty good I think.
Although the trail bike is in pieces.
Just a good reason to take the bikes on this trip. adapted easily. :ylsmoke:
Final weight snuck in under 65#
Proposed max load is a 125 swapped CT90, with a projected finished weight of 225# wet
Its pretty stout. but if I had to venture a max load rating, its probably in the 350-400lb range.
Certainly light duty enough that I wouldn't trust it to haul a big CC bike, indefinitely, with off road travel :)
Thanks.
Yes, the side entrance affords all kinds of benefits :)
Here are a few shots from the most recent trip.
Spent a good week and a half in central oregon.
Rack worked out fantastic.
Lightweight, and super easy to operate.
Bikes up high adds a pretty good level of theft security as well.
Thats what it IS designed for :)
Just do not have the moto together just yet.
Here is a photo early on to get things fitted correctly.
It will haul a little CT90. Resto-modded, with either a 125CC or 140CC swap.
Fj89
