Tell Me Why I Shouldn't Buy a WK CRD!
I just read last night that the GM 2.8L Diesel was in the little jeep sold for a yr or two in North America. Is that really true?
I was surprised to read that.
KJ CRD was 2005 and 2006 by Italian manufacturer VM Motori which is the same supplier GM uses. I sold my KJ before it blew up.
I just found one locally with 77k miles for $13k. I hope to take it for a test drive. Any complaints on these as daily drivers? I drive an XJ currently, and if i get this Id most likely do either an OME lift with 32s and daily it through Chicago weather
The WK is a perfect DD.
I have just stated looking for a CRD what the heck is a swirl engine?
Sent from my SM-G930V using Tapatalk
Another thing to keep an eye out for is affectionately known as "black death" on these Mercedes OM642 engines. (Google it for scary pics!) You won't be able to see it unless you pull the engine cover and foam sound dampers... But you might smell diesel fumes if it's present. All it really is, is a leak between the injector and the cylinder head. It leaks combustion pressure and gasses. This is another reason why It's always good to have an experienced mechanic, and in this case a diesel specialist, do a thorough pre-purchase inspection.
Personally, i don't think it's a deal breaker on an otherwise good find. But it has the potential to be a costly fix, so that should factor in.
A slight disclaimer/story here...
I'm a fleet mechanic, and former European car specialist, so things like rust and body damage scare me, while i tend to dismiss most mechanical things as " Well, i can fix that..." Makes me awful at suggesting what to buy! Lol.
Anyway, I actually found out about this black death thing with my own CRD purchase... After... i drove it 1300 miles home from the dealer... I've had the parts to fix it for about 6000 miles now... So you can see how much this really concerns me...
But it really does need to get fixed. It only gets worse the longer it's left alone.
Found another WK CRD for sale, here's the whole conversation with the sales guy:
Dealer:
08 grand Cherokee david/chase this is a 4wd grand Cherokee diesel are you interested?
Me:
Yes, but I'm disappointed that it doesn't have Quadra-Drive II, it's the first one I've found without it. There's another with the same miles, and equipped the way I'd want for $2k less than yours. I'm in Ft Lauderdale so this one is also 3hrs closer to me.
I'm a pain in the *** enthusiast that would like a WK CRD, but doesn't NEED one.
Dealer:
what would you like for me to do?
Me:
I don't know. If you come up with any ideas, let me know, I guess
Utah Bureau of Awesomeness Department.
QT2 which I am assuming it has...is not a bad system and you can add a true rear locker, unlike the elctronic limited slips of the QD2 system.
Another just popped up today with 55k miles on the clock. No pics or pricing available right now, but they are working on getting me that info.
**EDIT**
They want $13,900
I put a deposit on this vehicle, I will go to look at it in person Monday. I figured that I won't find another this clean, one owner, with only 55k miles again. I am not sure what I'll do with my 4Runner just yet.
You mean a seeping fuel injector? LoL
Every old Diesel I had at some point had some black crusty sepage on an injector at some point. No big deal. The bigger issue is that these transitional diesels were old designs being pushed with newer fuel systems. Todays designs are far better and will soon be out dated by clean diesel designs with all the silly exhaust stuff eliminated. Diesel just wasnt getting the development funding years ago. But is finally getting some much needed attention.
The new Diesel tech Mercedes is working on solves lots of the emmissions issues and related failures. Which will be really nice.
Jlbeats
