DIY Roof Rack Attempt
A few months have passed and I am just now getting around to update this thread.
Next up a roof rack... To start off let me say that all of this mess was just so that I could put a light bar on my truck. I really love the light that the LED light bars gives off BUT I've never really been too fond of how they look on 1st gens. So...
This is what I came up with...
This is how I did it.
Bought some 1/4" aluminum plate from a friend. He also had some strut that I was thinking I may use for the crossbars but I ended up tossing that idea to go with the 80/20 aluminum T Slot to save time.
Then I started working on the template using foam board.
After making the templates of the different pieces I transferred it to the aluminum and cut...and cut...and cut... Then I did some grinding....then a lot of sanding...
Now that we have the main idea taken care of, its time to figure out how to mount the lightbar.
This was my first attempt...
Using the original cheap mounts that came with the cheap light bar, I just welded some tabs on the end of some scrap channel that I had laying around. This cross bar was planning to be mounted to the side rails of the rack.
After looking at it from many different ways and possibilities..I didnt really think that this was what I wanted. I just felt like there would be too much stress on the mount when being jarred on the trail. So I scratched that. Decided to make my own mounts and just bolt them straight to the top.
Original Mounts.........................................My mounts
I just used Black oxide bolts to bolt everything together....which I later learned is the worst thing to use for something that will be out in the weather.... Black Oxide=controlled oxidation
