Forest Service Road Adventure Mobile
tk421
On your first page you mentioned that your camper will see some -40C nights, and I was wondering what your start-up plan is at those temperatures? Do you have an auto-start with thermostat installed, or a propane coolant heater? I see you have a generator, so I suppose you have electric power for battery/block heaters. I have started my gas engines at -35C when I wasn't able to plug in the engine block heater, but wouldn't want to rely on it in the woods. I sometimes carry charcoal and a metal pan to slide under the motor in those situations, but would be very interested in any Canuck tricks for starting at those temps without an electric source. Sorry if I missed it in your thread. Thanks.
Jonnyo
Its 17" .... a bit deeper then the usual due to extra insulation added in walls and in cab over plus I wanted the under bed storage deep enough to accommodate storage bins etc.
17 isn't possible. ;from the top of the side rail of the truck to the roof of your camper. I was basically asking how tall are the side of the camper that are expose above the box. Sorry if my English was bad. I m guess 33 to 36 inch range
mel
slem
<font size="3">Thanks for the great write-up and pictures of your ideal setup. &nbsp;So good to hear about the flexible&nbsp;design availability&nbsp;at Phoenix Camper, CO. xxc</font>
Runt
No worries....41" from topen of rack on camper to the bed rails of the Tundra. Overall height is 8' from top of rack to ground.
Runt
I have never had an issue. Blows my mind how great of a truck this Tundra is. Always starts in cold. I thought my 1st Gen. Tacoma was the best truck i ever owned....even better then my landcruisers but this Tundra is an awesome truck. Always starts and if I have an issue I do have a generator with the 12v jump start adapter and cables. Originally my plan was a remote start that would automatically fire up the truck at -30 like my old diesel gmc but I yet to do this. Likely won't....don't think I need it.
Runt
Phoenix makes good campers. Hardest part is knowing what you want. Rob can & will do almost anything you want.
Runt
That's an assumption. I'd like to hear from Runt if he's willing to respond.
Many reasons:
1. Low center of gravity. Pop ups keep your center of gravity low.....I go in rough areas and broken terrain. Hard sided campers once you start leaning a truck no matter how light affect your balance greater which leads to unloading weight on tires and losing traction.
2. Vehicle performance. Tundra does not seem to be greatly affected by the pop up far as acceleration. Still corners well. Did not affect fuel economy (14 to 16 mpg no matter what) but likely that is due to tire size (35's) & the weight the truck was already carrying due to bumpers, sliders, skids, winch blah blah blah .
3. Canoe on the roof. I almost always have a canoe with me and sliding it onto a pop up is easy.....hard sided with another 2 feet of height.....not so much.
4. Windows all the way around. I like the open feeling of a pop top when my windows are open.....its relaxing.
5. Phoenix Pop Up Campers options. I have every thing I could want in a camper, exactly how I wanted it.
That's just a few that came to mind.
Runt
Looking sharp Runt! Where about's are you working this winter?
Have a great Christmas.
Thanks. A little late on the response but better then never eh! Working all over the central interior of BC. The picture above is somewhere up the Nation....Mackenzie area.
bigskypylot
Just curious about winter temps and condensation. How much of an issue has it been? I'd love to do a flatbed model with some serious 4 season/winter upgrades. Love your set up!
Runt
Oh its an issue lol. When you stay in your camper for weeks at a time in the winter with temperatures down to -30 C often, plus the in & out in snow conditions you bring in lots of moisture. I give up on keeping water stains off of the pop up from condensation. Having said that I do wipe it down with a a chamois if I see it starting to "bead". The floor is easy to deal with because its Rhino lined and again I wipe down the flour. Honestly the condensation issue is over rated in my opinion, these are small spaces so its pretty easy to wipe it down a few times a day and ring out the chamois. When I get back home I put an electric heater in the camper with the top up and crank the heat with the vents open and it usually dries out in 24 hours. Far as temperature wise the only issue I have had is a week of about 0 during the day and rained at one point then it went to -5 C in the evenings so it was wet! and lots of snow. In one day it wen't really cold and dropped down to about -30 C. I dropped the top before I left in AM knowing I was moving camp when I got out of the bush. Top was very hard to get back up due to the fabric was frozen Ended up having to fire up the furnace and warm it up for an hour to get the top up. So far as winter temps that was the only issue besides condensation.
guapstyle
