Myvanisbetter
After a recent cold snap I've noticed a few things about the heater in my van.
It takes a while to heat up, and that is with a new thermostat from Ford. When the Tuner shows engine temp @ 190ºF the heat coming out of the vents is luke warm at best, unless the engine is turning 1500rpm or greater.
Coasting down hills in chilly temps, even with the engine revved, leaves the heat kind of lacking.
Running up a hill will make the heat nice and hot like I expect it to be all the time, at least in the front vents, the rear heat never seems to get warm.
The whole thing kind of has me stumped.
water pump failing? both heater cores blocked?
Help! :ugh:
Help! :ugh:
