M101a2 Overland Trailer Build
TTS
Good prices here dynation.com/Linear-Actuators/Windy-Nation/Linear-Actuators-various-stroke-lengths/-/244?p=YzE9Mjg=
Thats where I bought mine, 225 lbs capacity each.
I was looking at those in eBay. Think I can get away with 2 center mounted?
Martyinco
I saw one person get away with two, only reason I went with 4 one on each corner is to eliminate any possibility of binding, which is something I could see happening with just two in the center.
TTS
What stroke length did you go with?
TTS
Updates have been sparse lately as I have been busy working and not posting. We had a Memorial Day camping trip coming up and I really wanted to have the trailer ready to take and have it be useful as something more than a cargo hauler.
The first thing I knew I needed was power because I wanted to add a water tank and pump. I needed somewhere to put it so I began looking for a large tongue box that could hold a 10 gallon water tank batteries and power controls. I came up with this for $100 off a Facebook Marketplace ad:
After trying to install it I realized the I would have to relocate the hand brakes and that the tongue weight would quickly get out of hand. So I scrapped that idea and added a Harbor Freight 3 cu ft tongue box. I bolted it directly to the frame but went through 2 taps trying to thread the holes. :-( At the same time I added an adjustable wheeled jack.
Next was adding a trailer hitch to carry bikes. After bolting it to the rear cross frame member, I quickly realized that it was not stiff enough to hold the bike carrier without developing stress cracks. I re-enforced the back "bumper" by partially boxing it and welding the hitch to it.
Next, I was on to wiring the tongue box for power. I used a cheap deep cycle battery from the local Fleet Farm with a 175 minute RC, I don't know what that equates to in AH.
I also added a fuse block, main battery shut-off and waterproof switch for the water pump.
For water, I added a 20-gallon water tank from Amazon with a Seaflo 1.2GPM pump and Camco water filter.
I temporarily mounted this all to a board in the trailer until I can weld up a mounting system for under the trailer.
Lastly, I added some steel cable and clips to hold the tailgate level for use as a workspace. A 20lb propane tank is held in place with a ratchet strap until I get a proper mount.
[/URL][/IMG]
TTS
Resurrecting this for some recent updates to the trailer.
I added a rack with Compact Camping Concepts no weld rack and some square steel tube. The sides of the trailer needed some reinforcement from flex and I did this with steel U-channel behind the lip.
The tent is TuffStuff's Elite Overland 5 person. With 2 kids 11 and 14 years old we needed the space.
Now I just need to permanently mount the water tank and pump then build a drawer system with pullout kitchen.
507812
507815
507816
507818
Last1Left
Looks great building my out currently
eclipse179
