Ski Bum Truck V2.0, F450 Rough Road RV
java
Now you are ballin'. Hot water! That should make the missus happy.
Yep! Never had hot water in the truck before, we never used the water period in the old one. It's pretty damn hot here so we haven't really used it, but washing your hands sure is a nice luxury.
Batteries are at 87% after two nights, fans on medium or more all day and 90 degree heat keeping the fridge working.
52 feet of fun!
Made a DO pizza last night. Worked awesome.
Sent from my SM-G900T using Tapatalk
java
Here is a recap on the thrash that was Friday. Whoever decided I needed to get the water done before we left was a little nuts.... Needless to say, the three hours I had planned for it wasn't enough. Oh well, I dragged my *** out of bed at 6:30 and got to work.
I had to connect the tank to the water heater, both of which were installed at this point, then do all the tank fill side of things, install the water pump, wire all that stuff, and do the grey tank. (yeah typing all that out reminds me three hours were not nearly enough, planned to work 7-10, cleanup and pack and leave at 12)
So to start we have to install the faucet. Kids oil based clay works great for making a dam.
Now you hope and prey you don't break the tile.
Breathe again....
And drop the faucet in. One thing checked off the list.
Run water lines.
Hook up water pump, used flex here to try to keep noise and vibrations in the lines down.... Pump is god damn loud. Its a used one I have had in my garage for years now.
Install fill and vent.
Add water. Chase leaks. I hate threaded fittings!!!! PEX is awesome though.
Hot water coming out!
Apparently I took zero pics of the grey tank. Its the blue jug, its a hose barb fitting off the end of the strainer basket, a piece of 1" vinyl tube. Works really well actually.
Also made a drawer latch. Drawer holds a lot of stuff and likes to fly open when you turn! Yeah not good. Ball detent pin, drawer stays closed.
Reinforcement/latch plate on the inside.
Truck drove great all weekend, towed the boat at 70 no problem.
Stopped at the truck stop and got weighed. 3 people, 2 dogs, 1/2 a tank of water, all out stuff for a long weekend.
java
I'm learning a lot. Thanks!
That means a lot coming from you! :sombrero: Thanks!
Now that I know axle weights time to figure out suspension/wheels/tires. I don't think that single LT tires are going to cut it, just not enough load rating on the rear end.
colierar
I've been following along and just wow man. Great amount of work in a little amount of time. Glad to see you at least had some time to eat...
java
Who doesn't love a fresh roll of 2/0?! House battery wiring day
java
Where did you source that and how much did it cost?
CL! Found a guy who refits boats with a ton of leftover. It's tinned marine wire, made is the USA, paid 1.50 a foot. (100' roll)
I can get it locally from the marine shops, but it's $$.
