Ski Bum Truck V2.0, F450 Rough Road RV
CL! Found a guy who refits boats with a ton of leftover. It's tinned marine wire, made is the USA, paid 1.50 a foot. (100' roll)
I can get it locally from the marine shops, but it's $$.
Sent from my SM-G900T using Tapatalk
That's why I asked. Have not found any deals on that stuff.
It took 25' to get front to rear. Wow that was not fun. Its oiled up well underneath.
Disappearing into the beast
But its loomed and run the whole way! Need to get come more end connectors and run the ground.
Woohoo!! Its charging from the alternators!
Ground run to the frame. Ground the paint off and used an existing bolt/ground spot.
Connected at the battery (thoughts on an aftermarket/larger terminal?)
Make the noise! (Project Binky if you dont know the reference.... Check it out on YT, no affiliation.... :) ) Green light means the combiner works and batteries are charging from the engine. Solar controller and wiring can be seen here, and done as well!
All the electrical goodies to make it all work.
And a curtain happened too. Yes the truck is dirty.... we are using it....
Got a fuse near the truck battery end?
I've been trying to come up with a good battery terminal too. On my 2012, the Secondary (drivers side) battery positive terminal doesn't have the stud, only on the Primary (passenger side). Was thinking I'd just drill a hole and use a SS bolt with a jam nut to hold it in place
No I left the main run un fused.... Its been a topic of debate.
Never thought I would see a Project Binky reference here, those guys do incredible work. The whole series is worth watching, as long as you don't mind the dry British humour.
Back to your regularly scheduled (shed-yooled :D) programming...
They are doing amazing work! I've watched them all.... :D
Without a fuse at that source, you have a very long battery terminal extending all the way to the back. Albeit, it's insulated and has some protection, but you know...if it can, it will...
My plan (if I ever get to it) is to use something like this at the battery https://www.bluesea.com/products/5191/MRBF_Terminal_Fuse_Block_-_30_to_300A ,
Speaking of my plan, any of that 2/0 left over? May be interested in offsetting some of your costs so far.
Yeah There has been a lot fo debate over fusing not fusing, that looks like a slick system though. Ill look into it.
And yes I have half a roll left :D PM me
Look for marine style terminals or military terminals. Marine style terminals usually have a 5/16" or 3/8" stud. The military style terminals typically have a 3/8" bolt
HButton
