Another Gen1 Tundra Thread
AaronK
One of these days, I need to replace my radiator and upper and lower rad hose. They are due for a preventative replacement.
While I am doing that, I might look into upgrading the OEM tranny cooler. Low speed on trails in 4 LO stuff is normally fine, but 4HI will get a bit hot if I can do a higher speed. Seeing 200+, sometimes 220 and thats when I'll back off. Above 230 is no bueno.
Probably look at a Derale electric unit with thermostat.
Same here. And most of the stuff we do is fs road so I'm rarely in low range. Unless I'm pulling a steep incline and my temps really start climbing.
Sent from my A0001 using Tapatalk
AaronK
Well got it installed last night. Initially I was going to put the thermostat between the transmission and the radiator inlet. Ended up putting the thermostat between the radiator and the cooler because I also want to add a bypass valve so I can run just the trans cooler in warmer weather and switch back to normal operation in cold weather.
AaronK
Attended a Toyota owner's festival today. Was the only FGT represented there . Everything was people's choice. The only category I had a chance in was "best off road vehicle" but I lost to a rally scion.
Sent from my OnePlus One using Tapatalk
odonekanobe
Good to meet you yesterday. (Eric, in the ExPo shirt). You're telling me a Scion won best off-road? I would've been pissed if I managed to get my 4runner there!
AaronK
Good meeting you too! Yeah that rally racer in the corner won. Note to self, don't wash truck before care show. Pretty sure it only won because it was filthy
odonekanobe
I'm wondering if a truck will ever have a shot with that type of crowd.
AaronK
Maybe if the wording were changed from "best off road" to "best 4x4"... Either way I had fun hanging out and looking at cars. Loved the old corona
toyotech
Ah. I wanna go back to moab. This years trip with my friends had to be canceled.
AaronK
Much of my stuff is solo too. Al though it is not ideal don't be afraid to explore solo. You have a very capable built rig and mechanical sense :)
Aaron do top of the world!
Next time maybe. Heading out to do La Sal Pass tomorrow...10,400 feet! That'll be the highest I've ever driven.
Some more pics...
AaronK
Just in time for winter this showed up. Benmar 20,000btu multi fuel heater. In a pinch, I think I could use it as a jet engine. Gonna take some figuring out but if I can do it, the back of my truck should become akin to the center of a volcano.
Smudge12
