FOUND Vans For Sale!
Also not mine but WOW!
https://www.facebook.com/marketplace/item/535636353566651
2006 Ford E350 Box Van 2wd 5.4L V8 with 5 speed 5r110 Automatic Transmission 205k miles Transmission Rebuilt @188k 235/85r16 BFG All Terrain tires near new New Shocks, Suspension bushings, belts, and brakes front and rear Hellwig RV rear sway bar FRP Box Construction Seatbelts for 3 passengers Also have Ford passenger van rear bench seat with mounts and seatbelts that can be included 2 roof vents with Fans Huge Storage space over the Cab Walls and Ceiling are insulated with foam board and covered with cedar tongue and groove Floor is 3/4" thick rubber mat Large locking tool box Built in sink with hand pump/ 14 gal. freshwater underneath sink Custom Aluminum Bed frame to hold Full or Queen size mattress Bed raises and lowers utilizing E-Track brackets along walls/lifts all the way against ceiling for max cargo space and can be easily removed Can fit 6 mountain bikes or 3 dirtbikes underneath bed with room to sleep above E-track along floor in rear to tie down and secure loads Side Entry RV door with screen door Included but not installed: Dana 60 Front Axle with matching gears for 4wd conversion (leaf spring axle for U-Joint 4wd Conversion) complete with steering, brakes, sway bar House battery with mounts/solenoids/wiring to charge from Van battery Solar panel with regulator/ fuse box to power accesories LED interior strip lighting Must see to appreciate! 16k obo
Seems like an excellent starting point... perhaps a little high $ for 200k+, 12 years, 5.4
Last van looks like an ex-airforce flight line van. Around here they usually idle for hours on end on the tarmac to keep the box warm/cold for pilot transport.
Agreed - however that's CO pricing for you. At least it has the 5r110, I think that was only available in the cutaway chassis?
Anyway, thanks for sharing as I reached out for some more info (namely, any rust).
Also, ****** is this thing: https://denver.craigslist.org/cto/d/arvadarv-73-powerstroke-diesel/6778032501.html
However, Phoneix seems to be a hot bed for compelling 4x4 vans at the moment:
https://phoenix.craigslist.org/nph/cto/d/phoenix-2011-ford-350-ext-quigley-4x4/6774230362.html
https://phoenix.craigslist.org/evl/cto/d/gilbertdiesel-e350-4x4-econoline-van/6764340535.html
https://phoenix.craigslist.org/evl/cto/d/gilbertdiesel-4x4/6780064465.html
https://tucson.craigslist.org/cto/d/phoenix-12-gmc-savana-2500-quigley-4x4/6770668397.html
Wow that surveillance RV is cool. With rear ARB locker?!
Bummer on the tire blowout damage, but not the end of the world.
That's a cool rig and hard to find but $20K? They're out of their minds. With the damage and 250k plus the obvious interior wear and tear that's about $5k worth of metal.
Oh yeah, high price for sure. Cool setup though. Gotta wonder what places that was setup in its previous life. Guess they’re adding on the “cool diesel” tax...
Jlbeats
