Low amp, wet location connection for truck bed
DaveInDenver
Middle Income Semi-Redneck
Those PP outlets are a little spendy.
I carry my fridge in the curbside rear passenger space on a slide, but I may still add a standard 12V power point to the rear of the bed. It's too common to completely ditch. For my fridge cord, I'm thinking about ordering another to convert to Powerpole so I can go both ways. That would also make it less likely that someone would unplug the fridge from the center console to charge their phone (again).
What bed stiffener brackets are those? I've considered adding some if the GFC frame doesn't keep the bed sides together.
I have an Engel cable with Powerpoles, too. I convert almost everything 12V to Powerpoles because it's universal and I have a lot of amateur radio stuff, so it's interoperable. The fridge is really the only thing that doesn't use them regularly but that's only because she won't let me hack the rear outlet in her Forester...
The stiffeners are At The Helm.
Bayou Boy
I chopped my fridge cable for an SAE connector. Just used the other end with the cig plug on it with another SAE connector on it if i need to plug it in someone.
DaveInDenver
FYI to anyone not familiar with Engel cigarette plugs, there's a unique thermal fuse so you may want to leave enough pigtail and retain the actual Engel plug to make a Powerpole adapter for those fridges. The hardwire (like for MT60) harness or if you remove the cigarette adapter and just use the two blades in the ARB kit both remove the thermal fuse, so it's only a factor with cigarette sockets. It was apparently done due to some regulation in Japan for prevent accessories from melting the sockets free of plastic dashes.
john61ct
Most SAE are completely anonymous cheap Chinese stuff, can't find a proper datasheet.
I believe when I went looking for a known-good maker's data sheet, they rated 5? maybe 6A?
They do wear loose after not too many duty cycles.
DaveInDenver
shade
Thanks, all. I have a few 3M terminals on hand, but I know I need to restock. I somehow missed that crimping article while I was crawling around his site.
john61ct
Worth revisiting and parsing closely.
The more you integrate from other sources and experience, the more it all clicks together.
shade
Marine domain called clams
aka water-tight Cable Glands / Cable Bushings / Cord Grip Connectors
key modifier word is split, so the bushing gets assembled after the terminal is crimped, large connectors easily passed through the "grommet" hole
with Strain Relief more secure
just FYI
Back to this.
Does anyone have some suggested brands or retailers with a decent assortment of clams/glands? SailboatOwners.com looks like a good source, but I'm unfamiliar with what's good & not-so-good.
I'm starting to figure out wire routing, and I'll need a cable clam or two for routing wire into & out of the rear cab of my truck. I don't want to do it, but I think the best location will be on the rear wall of the cab, which will mean moving the truck bed back for installation. The other option would be through the floor of the truck, but I want to avoid blowing a hole through there. I still need to poke around to see if I can find an existing hole, but the rear wall of the cab seems the most likely location since it's central to the house battery, charge controllers, and the bed of the truck where most of the load circuits will be located.
shade
Thanks, John. I started looking at Newmar options, and will go through those sites. I really want this to be a one-time install, especially if I have to pull the truck bed bolts for access.
A pair of these might handle everything I'll ever need.
flipstick
