2016 Chevy Silverado LTZ Z71
D45
I see GM also makes a plug and play LED bed light kit
#23295943
#23295942
Whats the diff between the two?
Kinda odd......
#23295942 is for 2017 - 2020 Silverados
#23295943 is for 2016 - 2019 Silverados
SoTxAg06
Kinda odd......
This is how the light is mounted front the factory on my 2019. It doesn’t look like the lights for either of the above parts numbers.
Amazon has #23295943 listed for the 2014-18. Both parts say the will work with a 2014-18 on GM parts direct. It may be best to check with a parts counter at the dealership to figure out what the difference is, but they may not be much help.
Honestly, if it were me, I would order #23295943 off of amazon. If it doesn’t work, return it through them.
jbaucom
I don't know the difference between the 2 kits, but my 14 GMC came with the under rail bed lights, and I loved them. It's one of the things I miss with my F150. Once you get used to those extra lights, it's hard to go back to just having the cargo light on the back of the cab. When you have cargo in the bed that casts shadows, the bed lights really light up the lower bed where your tie down hooks are located.
D45
I was looking under the truck for the bed light kit hookup spot and also in the bed to see where the lights would be mounted
Very very pleased to find that I have the LED Bed Light Kit already installed!!! The lenses covers were just a tad dirty.
After a quick cleaning they are shining bright.
Haha!!!
D45
Ported and polished brand new TB.....so much smoother. Compared to stock:
The Injen intake will be at my house on Wednesday, so I'll install both at the same time
buellconvert
Haha!!!
That's awesome! That's better than finding a $20 in the washing machine
Sent from my Moto E (4) Plus using Tapatalk
  • Like
Reactions: D45
D45
Trying to debate what size lift......
2.5" front/2" rear.....simple and cheap for around $150
3.5" for $500
buellconvert
3.5" for $500
I was torn on what lift I wanted and actually still am, but for the immediate future I went with the simple 2" spacer in the front just to lose the ridiculous factory rake that most of these Silverado's have, I didn't do a thing to the rear...eventually I want to go with the Bilstein 6120 front coilovers and lose the spacer all together. The 2" spacer lift I went with was less than $50 and took me an hour in the garage and gives me a much better look and let's me decide how I want to proceed as far as a more detailed and/or expensive lift...
Sent from my moto e6 using Tapatalk
SoTxAg06
Same thing on my 19, which has a different suspension from the 14-18, but I went with the same concept.
D45
I helped to install two of the 2.5" kits on two diff trucks
Super easy and inexpensive.....but not that much different of an appearance than stock
I won't jump into anything for a few months and that will give me time to fully research lifts and options
SoTxAg06
I agree, my 2” level really didn’t do much. It will allow me to run a 33” tire, but that’s about it. I will likely go with a front replacement coil over and UCAs at some point.
D45
It seems like 33s are the limited size on anything under a 5"-6" lift
I definitely don't want anything that tall......and don't even want a 4" lift
I will be ok with a 33" tire , so I will focus my attention on 3" - 3.5" lifts.....likely with new aftermarket upper control arms
D45
Billet diff drop spacer kits are $30 shipped
Seems like they are needed for anything over 2.5" lift to help with CV angles
D45
Intake and TB will go on this weekend
Truck seems to do really well in the snow......even in 2WD
I love the V8 sound for sure, even with the stock exhaust.
The AFM disabler is working very well, no more cutting in and out of V4 / V8
Houie
