Isuzu NPR or Hino. Why not build on these?
2020 ISUZU NPR Crew Cab 4x4s are now available through Overland Adventure Vehicles
Reach out to us for a quote on a build ready chassis or box installed unit .These are top of the line builds running on 4 link coil over suspensions not back pounding leaf spring platforms.You can reach us at 833 717 2019
Overland Adventure Vehicles is proud to announce the production release of our Isuzu NPR 4x4 vehicles to the North American market.Our proprietary CAD and laser cut design parts are purpose built components to create a smooth ride suspension with 4x4 capability. Our conversions retain your factory warranty on the unaltered portion of your vehicle (engine, transmission, etc.). The proven, durable OAV 4x4 system provides greater ground clearance for off-road adventures. OAV 4x4 conversions are available in 150" and 176" wheelbase chassis.
OAV 4x4 System
4 Link Coil Over Suspension System
⦁ Rate Adjustable Tuned HD Coil Reservoir Shocks
⦁ Adjustable 4"-6" ride height increase
⦁ Baja Proven HD Trailing Arm Design
HD Kingpin Front Axle
⦁ HD Low Pinion Design Casting
⦁ HD Extreme Wall Tubes
⦁ 1 Ton (ABS) Big Brake Kit(Disc)
⦁ Free Spin Locking Hubs(serviceable bearings, unlike stock style unit bearings)
⦁ Ratio Specific Gear Sets
⦁ Tapers Roller Bearing Steering Components
OAV specified Advance Adaptor transfer case 2 speed (4Hi, 4Low)
⦁ Manual select 4x4 with indicator
HD Full Float 80 Rear Axle
⦁ HD 4" Low Pinion Design Casting
⦁ HD 4" Extreme Wall Tubes
⦁ 1 Ton (ABS) Big Brake Dual Piston Caliper Kit(Disc)
Black Rhino 17" Alloy Wheels
Pategonia MT 36"to 40" load rated tires
OPTIONS
⦁ ARB Air Locker
⦁ Coil Over Shock Upgrade
⦁ Bumpers and varies additional hard accessories
More details on the Overland Adventure Vehicles Isuzu 4x4 conversion would be much appreciated. Pictures, parts sources, website link, company history, qualifications, etc. would be very helpful. This would be worthy of its own thread in the Japanese Heavy Truck sub-forum. Having a reliable turnkey 4x4 conversion on the new Isuzu gas platform would be awesome.
Why not a promising option?
It would be nice to know who they really are and where they are located...
Did you read that jumble of mangled syntax? Their website is a hot mess too. Zero detail and not one photo of an actual rig. I hope I'm wrong but my little conscious monkey is telling me to run away.
Agree, at this point it looks pretty suspect. If they were going to have a roll out at Expo West this year they should have a completed truck to show by now. Unless the virus slowed things down. We shall see what happens...’
Dynamo TCX
