nickw
I was just pointing out in Australia the GVWR is somehow increased from US spec and from the std spec....wasn't sure what they did to do that, they have pretty strict requirements there, I remember reading something about it and I don't believe it was any structural changes.....If talking about physical weight carrying capacity, I think that converting to 2.5" coil overs will help there. Maybe the most important thing to upgrade is actually the brakes.
The existing wrangler brakes just aren't going to cut it. I plan to switch to the 'big brake kit' to go to dual-piston calipers.
If legally changing the GVWR is what you mean, I understand you can do that in Florida (where I live), but I haven't actually done any real research yet.
Good call on the brakes - probably are some simple axle upgrades you could do if required...
