Switch
Last winter I totaled my 2006 Tacoma & so now I'm starting over with a 2022 Tacoma Access Cab TRD Pro. My 2006 build appeared to be inspired by the Lemony Snickets books "A series of unfortunate events ":
The first thing I did was feel a wave of gratitude for the low cost of gasoline since my new Taco didn't require Premium.
Then we went on a dessert trip to Anza Borrego, Joshua Tree, Mojave, & Death Valley.
I had already added 33" BFG KM3 MT tires on a set of Toyota OEM wheels I had left over from my last Tacoma. The cap is a SnugTop that I found used on Craigslist.
I added my old ProRack rack so we could carry our canoe and search for water in California.
And then I started work on the suspension: shocks, springs, UCAs...
These are boring mods that don't need photos...
I also ordered rock sliders, bumpers and a bunch of stuff that has crazy lead times due to the ongoing supply chain issues.
In the meantime I started planning for additional electrical needs and added a fuse/relay box using a set of custom mounts that I designed and printed using my 3D printer. I also swapped out the factory battery with an Odyssey Battery PC1700.
For the truck bed, we use it as a sleeping platform. So I did a DIY bed rug
Yesterday I sold the SnugTop shell and got the ARE Z-Series truck cap that I ordered 3 months ago. It came with a Yakima HD bar which was a nice upgrade compared to my old ProRack bar. So I can finally start on the mods for the bed.
Build summary
Wheels/Tires (two sets):
2006 Tacoma Alloy wheels with 255/85R16 BFG MT KM3 tires. (Summer)
American Racing Mojave Teflon coated wheels with 315/75R16 BFG ALL-TERRAIN T/A® KO2 tires (Winter)
Spare is factory wheel with 255/85R16 BFG MT KM3 tire that fits in the stock location.
Suspension:
FOX 2.5 coilovers remote reservoir front shocks with Eibach 700lb 14" coils
Ikon UCA's
All-Pro Off-Road Body Mount Replacement
FOX 2.5 remote reservoir rear shocksARB Old Man Emu Leaf Springs with Extra Leaf Spring
U-Bolt flip
Timbren bump stops
4 Crawler 1" Body Lift
Armor:
RCI Rock Sliders
RCI Full skid package
RCI Catalytic Guards
RCI Front Bumper (steel) w/ WARN 103253 VR EVO 10-S winch
Brute Force HC Rear Bumper
Bed improvements:
ARE Z-Series truck cap w/ rails for Yakima rack
Wrap around shelves
Custom mounted switch panels, 12V, and USB ports
LED strip lights
Hi-Lift Jack mount
Yakima SkyLine Towers and HD Bars
Custom bed rug
Custom Canoe mounts
Other improvements:
5.29 Nitro gears
Custom mounted OEM fog lights on RCI bumper
Custom mounted Rock Lights
Side lights on ARE truck cap
Side lights mounted below A-pillar
Seat Jacker and Multi Mount Panel from Desert Does It
On Board Air compressor (OBA) under driver's seat
Custom mounted auxiliary fuse/relay block engine bay
Custom mounted taillight auxiliary fuse block
Cab auxiliary fuse block
Odyssey Battery PC1700 w/ NOCO Boost Plus GB40 1000 Amp 12-Volt Lithium Jump Starter
9-Switch panel in center console for independent control of all exterior lights
Redline Tuning 21-27015-02 Hood QuickLIFT.
DYI Dual Battery with custom control panel for switches and voltage indicators
Links to other posts that are relevant to this build:
Never eat a cold breakfast again
DIY Solar Panel
DIY Water Storage
DIY Portable grill
- I backed over a rock which tore off a mud flap and discovered the factory "mud flap delete mod".
- I crawled over a rock and discovered the "chopped exhaust" mod after I crushed my tailpipe so the engine wouldn't start.
- I sheared off a valve stem and discovered the TPMS system was a liability.
- I bent a shackle so I did a rear leaf spring shackle flip
- I had to replace my rear axle...
- And so on, until I'd done everything on my 2006 Taco except a snorkel and crawler box.
- Wrap around shelf
- USB power
- AC power (always on) why does Toyota bother with that stupid teaser AC outlet?
- LED lights
Build summary
Suspension:
Ikon UCA's
U-Bolt flip
Timbren bump stops
Armor:
RCI Rock Sliders
Bed improvements:
Wrap around shelves
LED strip lights
Hi-Lift Jack mount
Custom bed rug
Custom Canoe mounts
Other improvements:
5.29 Nitro gears
DIY Solar Panel
DIY Water Storage
DIY Portable grill
