New to me Xterra...
Maddmatt
7/2/21 Gobi Ladder installed
Quick and easy install after a 7 month Covid wait between order and delivery, but they honored the price and shipped 1st quality stuff. No real complaints. Install is easy, not worth a write up, but here's a couple pictures
Maddmatt
Are those some leaf spring load helpers on there? Did you install them? Do they help at all?
Thanks!
Yeah, cheap Autozone helper springs, I think they were $40. 10 minute driveway install, couldn't be easier. They make a surprisingly big difference, I tow a boat weighing about 3500lbs from time to time, these springs level everything out and if I even notice them when it's empty, I think they might make it ride a little better. Some day I'd like to put airsprings on it, but these were a great budget interim solution.
SC T100
Nice rig! I just picked up an '09 Off Road and am in the middle of getting it up to par. I was thinking of going with the Duratracs as well. Did you get Cs or Es? And have you been happy with them on the X?
Maddmatt
Thanks! It's my second one, the kids took my first.
To be honest, I have no idea what load rating, whatever Discount Tire's computer spec'd. No complaints at all.
YMMV, but: this is my third set of Duratracs on an Xterra (i have them on mine, and on the kid's X) - when I bought my first I was a dedicated BFG KO fan, but the Duratracs at the time (2014?) were slightly cheaper, and I liked the look. Within a month I had the opportunity to cross Colorado in Winter during a blizzard, what should have been a 6-8 hour drive turned into 14 as we drove back and forth looking for open passes - by the time we hit Durango I was completely converted to Duratracs - best All Terrain snow tires I've ever had.
They do start getting loud at around 40k miles, even with regular rotations, but on my first set Discount was pretty generous in pro-rating the tread life warranty, so it made the decision to get a new set pretty easy.
The hard core trail guys complain about the strength of the sidewalls, but for my use which is daily driving / weekend skiing / weekend boat pulling / 3-4 easy trails per year, they are great.
On my Pro-4X, after a lot of back-and-forth thinking, I went with the stock 265 size. I only have about 1/4" clearance in the garage with the ski racks on, but I'm kind of wishing I had gone with the 285's, purely for looks. If I blow out a sidewall or have other reason to activate the warranty on these, I probably will upsize - the rubber gasket on the bottom of the garage door is already torn anyway, I can probably tear out enough to make the truck fit....
Maddmatt
3/29/23 - Hitch plug relocation
Wow - almost 2 years since I've done anything to my Xterra but drive it, and this barely rates mention, but this is where I track everything.
Finally relocated the hitch plug - pretty easy job, not worth a write up, except to say there was no purple wire (following the instructions on the new plug) on my Xterra, but process of elimination determined that red equals purple in this case. Slightly better departure angle (the plug on my 1st Xterra is completely mangled....)
Kind of went overboard with the Hopkins 7 blade/4 pin combo, but for the extra $10 I like not having an adaptor. But it is a little big, I'm going to find a tiny "NO STEP" sticker for it....
Pics or it didn't happen...
Before
After
paulforeman
Before
After
Nice! That looks really nice. Not having an adapter will be nice if you ever find you need one and don't have one.
Maddmatt
6/17/23 - Fridge Slider
Pretty basic DIY fridge slider. I have a LION-COOL fridge I've had for some time, it's pretty cool (get it?), with the built in Lithium-Ion battery, you can somewhat lessen the worry about the truck's battery, in practice in hot weather, I find I get 6-8 hours of cooling time from a full charge, so in a travel situation, there are no worries, in a stationary situation, I've gone as many as three days with 80-90+ degree days just by plugging it into a portable solar panel during the day, and then letting the onboard battery run at night.
AND - later model Xterras have a 12v plug in the cargo space that's always hot, so less modification required.
First step was to replace the 12volt outlet with Anderson plugs, that made a huge difference in the fridge's abilities, those 12volt plugs are just bad.
Then I bought a general use fridge slide (Iceco) from Amazon, and the rest came from home depot. Basically plywood, some bolts, and a cheap rug.
Finished product is below:
And I was able to maintain access to the lower storage compartment
More information and discussion is here, https://www.thenewx.org/threads/bas...fridge-slide-install-diy.285682/#post-4410622 if anybody is interested.
Maddmatt
5/6/24 - LED Fog Lights
Purchased these from Z1 Offroad a couple months ago when they were on sale - pretty easy plug and play install, and didn't have any leftover pieces after pulling off and then reinstalling the grill and bumper, so that's always a good sign. Haven't had a chance to test them in the dark, but they seem brighter when pulling into the garage.
They look black when off, which is kind of cool - next step is new headlights. I could polish these, but after spending some time driving my wife's QX30, I got used to having significantly better lighting, so I'll be looking for a retro-fit upgrade...
Mitch Bears
