My first Jeep, a 1983 CJ7!
CaptainBuilt
Sounds great! Does it take a second to get it to idle right?
After first install it did. Now that it has done some self learning, it doesn't.
The only thing it that is different than a new fuel injected car is that you have to turn the key to the "on" position and wait for the system to turn on, then you can start it. That takes about 3 seconds. So, I just start it like a diesel. I've also found that when I crank the Jeep I'll turn the starter over for a half a second longer, and it gets the idle just perfect.
I've been driving the Jeep every day, and it's been great. I have found a leak that's between the engine and trans. It's probably the trans, since the engine is new.
It needs cleaned up, but we just moved across the country and it will be a little bit before I can.
guapstyle
