Zero budget just get out there adventure van
joeblack5
Great job on the van and keeping up with the maintenance and of course the pics. I am impressed with your rust repairs. Are you spraying hollow wax inside to prevent condensation. And rust from the inside.
Good luck, johan
RVflyfish
Fishing is life. The rest is details.
Tell us more about this hollow wax…
Haven’t heard of it, but it sounds like a really good approach. Can you spray glue insulation to it?
JamesReddish
Good luck, johan
Thanks for the kind words,
My approach so far has been to use brush on Waxoyl on the underside/under the arches. Then into any holes or areas I can't reach I have used aerosol cans of stonechip.
I think what @joeblack5 is referencing is if you have a compressor there are a variety of nozzles available that allow you to feed a tube deep into the chassis or other components and coat them from the inside with a rust protection product. Like this -
Correct me if I'm wrong?
joeblack5
Yes, that is what meant, waxoil.. dinitrol.. I am sure there are more brands available.. it delays existing rust that starts from the inside.. a lot of rust begins between the metal at the seams that are spot welded together..
Johan
RVflyfish
Interesting. Does it stay wet or does it dry? Do you need to reapply it, and if so, how often?
JamesReddish
I think that depends on the product chosen, the Waxoyl I use stays as a waxy finish that never dries, and sort of 'heals' over a stone chip. Although I do reapply it anyway.
JamesReddish
Another reason I love having the van, just so handy to have for life jobs.
Moved a friends motorbike. (Still to put my own in the van even though I've moved a few for other people)20231126_082222.jpg
Used a sketchy ramp, so decided to make my own to fit and work better.
Perhaps I'll get around to painting it and a couple of finishing touches before it gets used.
And also did a huge tip run from a complete bathroom makeover.
Jalopy77
Moved a friends motorbike. (Still to put my own in the van even though I've moved a few for other people)View attachment 808705
...you're right James. You just can't beat a van for getting stuff done. If I had a dollar for every time a friend or family member needed soemthing shifting I'd be a wealthy man.
Well, I'd have a fist load of dollar bills anyway!
JamesReddish
Yes absolutely, any fuel money is welcome here!
nelstomlinson
You asked about what tools to carry. My plan is to carry parts that I might reasonably change on the side of the road, and the tools to do the job. E.g. I want a spare tire, so I carry a lug wrench and jack. When I drove a power stroke, I carried a cam position sensor, and the wrench that fit. I carried a spare power steering hose, and the wrenches, and power steering fluid. I've had to change each of those in parking lots or roadsides.
JamesReddish
My thoughts exactly, although I'm now getting to a point that I need to sort out more space for the tools/spares. I'm really not sure what to do so I can keep everything stored away neatly. Especially if I take extras on longer drives.
Mitch Bears
