Hodakaguy's TW200 Thread - Mods and Misc
Jupiter58
Very nice! Cant wait to hear how the new suspension goes in the wild!
Love the light!
Which bars are those?
How is the clutch? I found mine to be hard to adjust. Not crazy about having to open the primary to do it.
Hodakaguy
Love the light!
Thanks Mate. The bars are Renthal Fatbars 609 RC High.
My clutch seems very solid, should he able to adjust the clutch at the cable down by the clutch arm.
Hodakaguy
texasnielsen
Outdoorsman
Great write up (as we would expect from you!). Really liked the headlamp mod as well. This thread is a keeper for so many reasons regarding my own T-dub.
Thank you for taking the time to document all the work you did.
Hodakaguy
Thanks Mate, I enjoy doing write ups and always hope they inspire/help others in theor own builds. I got my LED bulb in for the race light today so I'll get that installed soon and give it a try.
Hodakaguy
Hodakaguy
Got the TW's out for a New Year's Eve Ride and had a blast up above the fog. New suspension worked awesome!
Full Ride pics here: https://www.advrider.com/f/threads/riding-above-the-fog-on-the-tw200s-new-years-eve.1693921/
Hodakaguy
Hodakaguy
Flashing LED Tail Light
This is a simple and quick mod that adds safety by flashing the brake light before going solid ever time the brakes are applied. The flashing light does a great job of grabbing drivers attention that your coming to a stop, and on the street visibility is a good thing. I've ran these kind of flashers on most of my previous street bikes but they have always been a dedicated flasher unit you had to wire into the bike. I found these LED bulb replacements on Amazon with the flasher built into the bulb...Nice, plug and play!
Install is as easy as changing the rear tail light bulb. Swapping the incandescent bulb out for the LED unit also lowered power consumption by .4 amps. The bulbs were $14.50 for a two pack...not bad.
Note: The links below are my Amazon Affiliate links. I make a small portion each time someone purchases from Amazon using one of my links, at no extra cost to the buyer. I only provide links to items that I personally like and use myself. I use the money to put back into my builds and support making videos/posts. If you prefer not to use my links, you can search for the same items directly off Amazon. Thank you for the support!
LED Flashing Tail Light Bulb (Bulb 1157 in clear)- https://amzn.to/3S5p9um
Old vs new. I went with the clear LED bulb which works great with the red lens.
And a video showing the install and the bulb in action.
Hodakaguy
Hodakaguy
Walk through of the GL tank bag on the TW.
I was asked a couple questions recently about the GL tank bag that I use, such as how easy is it to fill the fuel tank and remove the bag. I've ran GL bags for years and love them, they work great and hold up really well.
I made up a short video showing the function of the GL setup here:
And a few pics.
I have power ran into the tank bag and charge phones, camera and drone batteries while I ride. The SAE to USB charger is 3.4 amps per channel.
SAE to USB Charger - https://amzn.to/48LUJmj
In the rear pouch I keep my wireless heat troller and the connection for my heated gear.
The bag is zipped to a base that is strapped to the bike. To remove the bag just unzip on both sides. To fuel up just unzip one side and flop the bag over to get access to the fuel cap.
Hodakaguy
Hodakaguy
Chubby Buttons: Glove friendly audio controls....and a custom mount.
I like to listen to music through my helmet on longer rides and have a Sena 20S set up but I've always found using the helmet controls a pain to scroll through music...especially with winter gloves on.
Enter "CHUBBY BUTTONS"...a wireless, weatherproof, glove friendly solution that works brilliantly. I've used these buttons while riding my Onewheel for a couple years now and love it.
Now to fabricate a mount to hold the Chubby Buttons on my handle bar clamps, within easy reach when I want to change volume or switch Tunes...even with gloves
Chubby Buttons - https://amzn.to/48LUJmj
The Chubby Button Unit. It's light weight with good sized rubber buttons.
I'll make the mount to fit under the GPS, on top of the handle bar clamps.
I'm making the mount out of a piece of 6061T6 Aluminum flat bar.
An aluminum cut off blade makes quick smooth cuts.
Here I'm using a washer to lay out some radius corners. I'll use a jig saw to cut them out.
Test fitting...yep this should work.
Drilling the holes I'll use to run snap ties through and secure the Chubby Buttons to the mount.
Painted.
Continued Below....
Hodakaguy
Continued from above...
I used painters tape to keep the aluminum bare on the back side where I'll apply 3M VHB tape to attach the mount to the bar clamps.
Applying and trimming the 3M VHB Mounting Tape to the back side of the mount.
Using snap ties to attach the Chubby Buttons to the mount.
Metal surfaces were cleaned with alcohol then I used a heat gun to warm up the metal for good adhesion....warm not hot.
Continued Below....
Todd780
OverCamper
Awesome build! Def going to check out that Antigravity battery and flashing brake light for my own bike.
Great write ups as usual.
I’ve got ask though, what the heck are those god awful hand guards for? Wind protection?
Guessing so? Might be chilly there so it's either those or Hippo Hands.
Tex68w
Beach Bum
@Kingsize24 you guys are kind of kindred spirits with the bikes and fabbing up stuff, y'all should share ideas on the 200!
I love the TW build, but what are the details on the old Beamer? I had a 1961 50/2 that I restored, I sold it because I liked looking at it more than riding it but they still turn my head every time I see one.
AZXPLOR
