is the 1st gen tundra one of the best platforms
TLar25
Unfortunately Doug Thorley currently makes nothing for the 1stgen Tundra double cab.
Huh, guess I assumed they did because they make them for just about every other Toyota with the 4.7 and I could've sworn I'd seen people with them online, but I guess not. Looks like JBA has some options
Sent from my SM-G975U using Tapatalk
Lemmy
Your old Tundra looks great!
I gotta know more about the silver one on the left, and how they lock down that topper after elevating and letting it back down
Thanks! I am super into it
Buddy’s Tundra is running this for the camper shell, pretty slick but $$
beef tits
There are long tube headers available for a 1st gen Tundra. (Insert any manufacturer)’s long tube headers will make way better power over stocks.
Doug Thorley is nothing special, just the go-to headers for the GX/4R 2UZ
dalday
4.7L motor is solid. However, they all have issues with exhaust manifold leaks/cracks. MPG not great. Later ones with 5 speed and VVTI was slightly better. Turning radius is BAD!!! The 2G Tundra is easier to maneuver even with the larger size due to the tighter turning radius. Heck, the Tundra turning circle is the same a the Tacoma (DC w/ 6ft bed). And it turns tighter than ANY full size truck. Both Taco (all) and late model Tundra are better. Suspension not as easily modified compared to 2G Tundra or Tacos.
Other stuff I don't like: dash that resembles the oval era Ford products (Taurus, F150/250s, Expedition) and column shifter (no thanks).
2G Tundra is better in all areas except wider (when fitting in tight spaces). 5.7L dominates the 4.8L in nearly every category: power, mpg, timing chain, etc... Plus better 6 speed transmission and 2016+ trucks have 38 Gallon Fuel Tank (I'd easily travel 600 miles per tank on mine). I've owned a 1998 Taco, 2013 Taco, 2010 Tundra, 2016 Tundra and looked seriously numerous times at the 1G Tundra.
Spoken like someone who hasn't owned a 1st gen. 😆 But seriously I think the comparison needs to be with a double cab taco as 1st gen Tundy is better in every way (see visibility) and nearly identical in length and width. 2nd Gen tundra should be compared with like-sized (massive) modern 1/2 tons, which it is better than the competition no doubt. 5.7 / 6 speed / diffs in a first gen is my dream rig.
phsycle
I’ve heard this repeated so many times. But lets fact check:
dalday
That is the short bed taco, in comparing apples to apples the 4 Dr 6' bed taco is much closer in size to the first gen tundra which also has a 6' bed. See revised chart.
Also someone noted earlier, the 1 gen tundra is 75" wide if not accounting for the oddly large plastic fender flares. You can double check this by checking width of the base trim tundra like the single cab which did not have fender flares. 2nd Gen tundra are 79.9 without flares so the cab is 5 inches wider. Which is why I suspect they feel larger. Taco no flares 72.2 wide which is partly why they feel cramped.
Apparently no 6' bed in the full 4 door crewmax 2nd Gen?
Further proving my point, the new 24 crewmax (full 4 sized doors like first gen) and 6.5' bed is a whopping 246” long 158” wb, imo, I would say by today's standards the first gen is a small roomy truck with a V8.
CharlieGreenT
