Need a real axe
bucketosudz
As Superu suggested, the steel that makes up an axe from "Box Stores" and from lets say "Wildland Fire Supplier's" are not necessarily created equal.For the sake of conversation, you can think of it as a knife if you will. All knifes with some attention will cut and poke, but it may not last as long or hold an edge as long. They may be brittle, or bend when accidently struck against a rock or ground. Ask a Forester or Wildland Firefighter or Structural Firefighter what they would be suggest. Council Tool and Nupla are a couple of brands to consider.
Tom and Elaine
Can't beat the Estwing for weight, ease of sharpening with a mill file and round stone and it will hold an edge unless you are splitting rocks. Weight is minimal, I have carried mine on backpacks ATVs snowmobiles and vehicles for years. It now has a comfortable home in the Tenttrax.Best part you never have to replace a handle. Tom and Elaine
jcbrandon
...What do you do with a pulaski?
The head has two tools: One is an ax for whatever you would use an ax for. The other is a grubbing hoe or mattock. It is designed for chopping tree roots. It works great for moving things like rocks out of the ground. Think of it as pry bar, or an ax blade turned 90 degrees -- that you don't mind cutting into the ground.
Here's an explanation on its use in trail building:
http://www.americantrails.org/resources/info/tools5.html
I almost wrote "Decorate your truck." :)
T-hacha-P
I would recommend checking out a Fiskars ax. They own Gerber, so the hatchet you have was probably made by them.
Sears sells them cheap
http://www.sears.com/shc/s/p_10153_12605_07183521000P
or you can buy the same damn thing rebranded as a Gerber for not-cheap
http://www.gerbergear.com/index.php/product/id/144
This ax is great: light, controllable, and goes through oak like nothing. No bells and whistles, just a great product. It never leaves my truck.
I got mine at a Sears attached to a trendy mall in the Valley, where there are a lot more people walking around buying Gucci bags than shopping for tools. I made my wife carry the ax. If you ever want flat out stares, walk through an urban mall with a tall hot blonde in a pink dress who is carrying a bright orange ax...
xcmountain80
Gocha I knew what a mattock was but the other thing was new to me.
Hahaha that would have been funny.
VikingVince
I agree with Fergie. Look at all equipment as if your life might depend on it. (within reason, I guess) The Estwing is a single tang axe...no joint between the axe head and the handle...that joint is the weakest part of any axe with an axe head connected to a handle and if it breaks when you really need it...well....
s7_511060_imageset_01
Cabelas has two sizes of this axe.
xcmountain80
Hahahahaha :Wow1: I can imagine actually, that's a riot . This would probably suit my need as the hatchet while cheap looking works very well I just wish it was heavier.
Aaron
Something
Will all of these axes rust if kept outside all the time?
I want a good option to mount to the bed of my truck.
jcbrandon
I've got mine mounted in an open truck bed with Quickfist clamps. After a couple of months of winter weather, it started to show light rust on the bare steel portions of the head. I brushed the rust off with a scothchbrite pad then gave it a light coating of spray paint. Figure I might have to do that once or twice a year. But I live in a very dry climate so that may not work for you. The handle is fiberglass so no worries about rust on that.
Something
I can live with that.
Thanks!
colter
gransfors bruks axes are the best I've ever used hands down. they're more expensive than most but are worth the money.
X3 on the Gerber/Fiskars
I own the Axe and the Hatchet. They are the best Axes I ever used. Everyone I camp with loves using them also, even though they all have thier own.
Mine stay in the vehicle, so I'm sot sure about the rust.
TCM
Adventurer, Overland Certified OC0006
JCCB1998
