The pump is a FloJet LF122202, or something
It was provided from the PO, but never setup or used. Sticker on it states it flows 1.1gpm and is automatic/ondemand. Quick testing looks promising!
I mounted the pump inside the trailer, to the drivers side of the fridge drawer via rivets through the pumps rubber feet. I'm hoping to keep it protected from the mud and rocks it will see on the trails, but I'm already having second thoughts about whether I should have left it down on the frame, hmmm.
I have an inline water filter enroute and will be installed inside the trailer as well. I'm thinking about adding an eccotemp tankless water heater, but first need to figure out where I could mount
Oh well, onto the pics :coffeedrink:
Tanks plumbed together:
Input line nice and sealed up. You can also barely see the 4 rivets poking through via some silicone sealer:
Pump in it's current position. Don't mind the loose wiring and output hose, those still need final adjustments
