Trail Outfitters 1990 FJ62 Expedition Build
Well she is finally done and off to her home in the Bay Area.
The owner threw a rod on his 3FE and figured it was a perfect time to upgrade the Cruiser the way he has always wanted.
Here is his Daily Driver/Expedition Build...
Drivetrain
1995 Suburban TBI 350 with a fresh rebuild
Painted our standard ford Grey and Satin Black
Advanced Adapters adapter to rebuilt and cooled down A440f
Airraid Intake
MSD coil/cap/rotor/wires
Champion aluminum radiator
Summit dual electric fans
Summit headers
Howell wiring harness and ECU
Optima Red Top with Trail Outfitters Custom Optima Box
Basically completely rewired everything in the vehicle due to some "funny" wiring
Custom trans cooler lines, oil cooler, and power steering cooler lines
Custom exhaust with Flowmaster muffler
WORKING AC
Basically everything under the hood was customized
Suspension:
New spring bushings
SOR Lift Shackles
Sway Bar bushings
Lighting:
Rewired his existing roof rack lights with dash mounted switches
PIAA 5100 series driving lights
Wheels:
Powder coated the stock Cruiser wheels and caps
Black anodized lug nuts from Summit
Armor:
Custom Rear bumper with swing out tire carrier
Powder coated
Built in hitch
Swing out support shock
End caps built to look as close to stock end caps as possible
D-ring mounts and d-rings
Custom Front Bumper shaped to fit body lines
Powder coated
PIAA 5100 Driving lights recessed and wired to dash switch
Viking fairleeed recessed flush with bumper
Fully enclosed Warn M8000 winch with removable cap (built to protect the winch from Bay Area weather and Bay Area crime)
2" Bar
Extras:
Fully painted the engine bay, inner fenders, radiator support, and front half of frame.
Fixed his pre-built ladder to hug the body closer...NOT OUR LADDER BUILD...I REPEAT NOT OUR LADDER BUILD...:sombrero:
Happy owner...
I assume we are talking about the restored 60...
We haven't driven it enough to get a good idea. As soon as it is complete I will take it for a LONG test drive and get that figured out.
Not sure on the MPG for the TBI 62. The owner is coming by next week on his way to Tahoe. I'll ask him then.
Scott
SLOwag
Hmmmmm...I need my rig to throw a rod. Beautiful truck, I may need to discuss my needs with you in spite of a still functioning motor.
Just drain all the oil and drive it up here! That should do the trick...:smiley_drive:
I'll send you a pm and you can enlighten me on your vision.
OMC
Scott
Did you stick with the OEM transmission torque converter?
eclipse179
