Mg-rover1
Well, in that case, no.
Would work for the first few minutes, and then wear off.
I'll try it next time I go out, be a fun experiment.
Don't forget to bring bacons:victory:
I spray Pam in my nose every night before I go to sleep. In the morning, the boogers fall right out. Great trick for people with sinus problems.
Wouldn't using WD-40 or other petroleum agents which will slough off into the ground and water supply while off-roading be a concern for pollution???
Great for the inside of a horse's hooves when in the snow...
As has been mentioned, some dirt track racers I know will put WD40 or cooking spray on their suspension and frame components to help keep things cleaner when the track is wet/sticky, but a good friend doesn't because his logic is that he can either spend 5-10 minutes spraying WD40 on his car before the race, or spend 5-10 minutes spraying his car with the power washer after the race and get the same result with less expense (they have their own power washer). I suppose it all depends on the application. Motorcycle fenders makes sense to because they fit closer to the tire and build up could be a problem. Late model race car with no "fenders" over the tire, not as much. I've never thought of putting it on tires.
I should put some on my dog's feet so she doesn't get ice balls between her toes...
OK, that's thinking about it backwards. Purpose of this application in racing is to eliminate the weight of heavy clay/mud and give you a potential weight advantage against the competition.
a little "cleanup lube" makes it enjoyable, even the morning after.
