Project: Doitall Dodge
Metcalf
I got some new accessories in the mail today.....
EGT, fuel pressure, and boost...
Now....where to mount these dang things?
Metcalf
The pillar is an option for sure. I am hesitant to mount them there because of the 'wanna race' diesel truck scene in the southwest. Pillar gauges generally attract a lot of attention.
My most recent thought was to replace the 'information' cluster above the climate controls with a 3 gauge mount. I think I could french in some modeling plastic sheet pretty easy and paint everything so it looked pretty factory. I would lose the indicator lights for ABS, wait to start, and water in fuel unless I spliced in some new bulb holders and moved them somewhere.
Does anyone know if a small indicator light ( regular bulb style ) that is panel mount and you can add a lighted label of some kind to?
Bogie
I'm a fan of under dash mounting bu I use the larger 2-5/8" gauges. check out K-4 Electrics for indicator lamps
huntsonora
I love your truck but the last thing it reminds me of is a race truck:sombrero:
I like the pillar because they are easy to see and out of the way
Drummond
Metcalf
I know it's not a race truck, but all the diesel heads around here don't seem to be able to make that connection....
Pillar gauges also say ' look in my truck because its pretty modded', which is attention I don't like. And yes, you can still see in the windows really easy. Maybe I should lift it? :sombrero:
Bogie,
Thank you SOOOO much for that link. Those indicators will be perfect I think!
Metcalf
My wheels showed up yesterday....tire are suppose to be here today or monday! :drool:
Does anyone know how to get the pushrod for the clutch out of the clutch master cylinder? I have been having problems with the bushing system that connects to the pin on the pedal. I made a quick steel bushing last night and that helped, its being held in by some duct tape....
I need to make an adjustable and replaceable pushrod with a small heim joint or something. Then I need to replace the pin on the clutch pedal, it has a large gouge on one side.
Without the rigged up bushing I could hardly get the clutch to disconnect enough to shift!
Rot Box
I had the same bushing problem with my 92. I ended up having to weld up the shaft and grind it back down smooth because the groove in it was so deep :Wow1: I was able to get away with a home made bushing, but I want to say the dealer has that rod end but I cant remember... Its been too long ago.
As for the gauges I really like being able to watch the pyro and keep my eyes on the road. My Pyro and boost are on the steering column and I like them there. Here's a pic of mine (lots of clutter I know LOL :snorkel:)
Metcalf
I love the smell of new tires in the morning....
Excuse the mess....
At least 1-2" taller than the old 325s unmounted. I would suspect with air on a rim they will be just about perfect....
The tire and the tread are MUCH more beefy in person! The tread is also nice and deep at 21/32nds.
Me like.....
Metcalf
I'm working on it....
I have a few things to do first.
-I need to check the alignment to make sure its close.
-I'm thinking about using some 3m weatherstrip adhesive on the beads. The dodge doesn't need bead locks really, but having a little extra insurance in the sand and snow when running low pressures would be nice. These tires are going on slightly wider rims than before too. The Michelin's where just fine....even at LOW pressures I shouldn't probably talk about.
Metcalf
Ack....I ordered a lot of stuff today. Dang tires got me more motivated I guess...
I have a new grill shell, turn signals, headlight bucket, and grill insert coming.
Then I ordered some bronze ampco 18 kingpin bushings.
Then I got a few odds and ends from McMaster like some ABS plastic to make a gauge mount, some heavy thick washers for the new kingpin bushings, and a neat 4" plastic plug to make an HVAC clean out!
I am going to try and get the tires mounted on the rims tonight after work.....
Dang never ending project truck!!!!!!
I really need to do something better with the clutch pushrod master cylinder clutch linkage.....
Metcalf
Its fairly common with the 'wheeling group I run around with. While it does help, its not ultimate. The report from the last deep snow run indicated that it didn't hold as well as most thought it was going to. Dismounting the tire really isn't a problem. The stuff breaks at the bead easy enough...though needing more force than normal.
I ran the black bead sealant for years on all my rims. I had pretty good luck and VERY minimal bead problems.
DanoWall
