Hello I'm new to expedition portal. I have had my samurai for about a year and boy have plans changed. at first I was going to build a nice mostly stock rig with a spring over and 31" tires. then I thought about a dedicated crawler and that just seemed a little useless to me. so I have tried to combine the two. I started off with a 88 soft top
and decided I would be happier with a tin top so I did a body swap about two weeks ago.
I have most of the suspensions finished. I'm running a Toyota front Axel with 5.29 gears high steer and a Toyota ifs steering box. the rear is a trail gear rock assault for the samurai so the diff is off set to the right side and 5.29 gears . I'm running a 4.1 transfer case and heavy duty Toyota drive lines. my springs are 5leaf wranglers in the back and trail tough rear with reversed eyed springs up front. I'm running 35" BFG km2 on 15x8 eagle 589 wheels. The motor is stock so it passes smog in California but it has fairly low miles.
it still sits in the garage for now. I only need to do a couple more things to get it drivable. I will be doing bumpers and a rack soon. sorry but i only have a couple of pictures for now. the pictures are a little old but I will take some more and post them soon.
[/QUOTE]
Not the best but here are some newer pictures
I still need to do the in side and put the front clip back on. and maybe some paint.
