Question for users of older diesels.
Rot Box
random
I persnoaly dump a quart of ATF in every tank started in gillette at the mines. Helps with gelling and adds a but of lube back to the mix also helps clean it up.
This is what I do. The place I usually fill up at has no-name atf for two bucks a quart. Since I've started doing this, I've noticed a little bit better mileage, a little more power, slightly quieter running and my metering valve not sticking.
flipstick
