1996 K1500 Build
djp73
Accessories going onto the new engine.
djp73
Fall 2018
replaced regulators on both doors, speakers too
installed missing lock rods etc on drivers
replaced pass side window as the track was rotted off
bought a remote from amazon for $20 and got the keyless entry working
djp73
October 2018
I got a really great deal on a set of Firestone Destination MT in 315/70/17.
Then I just had to decide on and buy wheels to fit. Landed with 17x9 -12 American Racing AR72 in black.
Had to pick up the front a bit with the torsion bars to fit, rub the rear of the wheel wells some at full lock, I'll let them self clearance.
djp73
November of 2019 I decided to clean up rust and paint the back half of the frame. Dad suggested pulling everything off the frame to do it right. So who was I to protest. Took it right down to the frame rails.
First step was to pull the bed off, used a come along into the garage overhang rafters.
djp73
Make it all black. ORD shackle flip, replacing the 4" lift blocks, shown in this sequence of pictures.
djp73
Reassembly begins. ORD shackle flip, ORD UBolt flip and Dorman stainless brake lines among the additions.
you can see the ubolt flip here, done for clearance and to get rid of the rust holders that used to be on the bottom of the axle.
djp73
Mostly finished going back together.
Back outside for the first time. During this process I also installed a 1.5" body lift that I put together with Zone 3" pucks I cut in half and a sourced longer grade 12.9 bolts. The bolts were all OE GM/Chrysler bolts that were the sizes needed. I wanted to use those to be sure of quality and to get the build in washers that the original bolts had.
abctrash
