1996 K1500 Build
djp73
NOVEMBER 2019 Still
Front end up on the wheel lifts to get some scraping, grinding and painting done on the front half of the frame.
djp73
NOVEMBER/DECEMBER 2019
Bed next. Ended up having my buddy who does some body work put a wheel tub in it and patch a spot on the floor. Underside was decent. Scraped, ground and painted.
djp73
FEBRUARY 2021
I wanted to get a locker in the rear of the truck but I didn't want to spend much on the 10 Bolt that I was/am replacing. Went with a Spartan, under $300 on Amazon. Easy install, took a few hours.
djp73
APRIL 2021
Sold my EP3 and put the Kenwood in the truck, replacing the junk Blaupunkt I had in there. Kenwood is an older unit but was high end at the time, great for a vehicle I don't drive all the time.
djp73
JUNE 2021
At this point I had been building the truck in my head for several years and always intended to swap to a solid front axle with leaf springs. The first piece of the puzzle popped up on craigslist. A 77-79 F250 Dana 44.
The use of a Ford axle has the following benefits:
Differential on the left, allowing the use of the stock axle
High pinion
The Chevy outers all swap over allowing you to put together a hybrid axle that gives you left side drop, high pinion and Chevy 6 lug. That's the plan.
djp73
Next piece of the puzzle was coming up with a Chevy Dana 44 so I could harvest the outers the Ford axle to 6 lug and also getting a flat top right side knuckle that can be machined and tapped to accept a high steer/crossover steering arm.
All the trucks from the 70s and 80s had the u shaped steering arm on the left knuckle and used the front to back steering. This not only sucks but it won't work with he steering box in the truck.
The solution is crossover steering that uses a long drag link to cross over from the steering box to a steering arm on the right side knuckle.
Chevy D44:
old steering:
crossover steering:
djp73
SEPTEMBER 2021
finally replaced the starter it's needed for four years, went with the gear reduction. no more "will it start"!
also, five year anniversary with the truck today
djp73
NOVEMBER 2021
For the rear axle I elected to upgrade to a 9.5" semi float 14 bolt. This axle was used in F44 "heavy half ton" trucks and 6 lug light duty 3/4 tons. A 5 lug version was used in 454SS trucks. It's not as robust as the big 14 bolt full floater but it allows me to stay 6 lug and to keep weight down and ground clearance up.
This particular unit came from an old friend who now lives about five minutes from me. Also scored a few other small parts, some of which can be seen in the picture below.
djp73
December 2021
Scored this cap from a customer who had an F150 that was totaled. I noticed the cap didn't fit the Ford well and turns out it was on his K1500 originally. Offered $100 and snagged it.
djp73
December 2021
Decorated for Christmas. Big hit at daycare pick ups.
Version one:
Version two:
djp73
March 2022
Parts started to roll in, one of the most exciting ones being the Eaton e locker for the front. I wanted something selectable for the front and the Eaton was the most appealing to me.
abctrash
