chequamegon
I have a 2004 Land Rover Discovery SE, loaded. It has 92,150 miles on it, and is in perfect mechanical condition, all lights, switches and other objects work 100%.
The SE model is the higher end, with leather, heated seats, dual moonroofs, dimming mirror, homelink, foglights, etc.
This truck is extremely clean, and well taken care of. I am picky about cars working, so I maintained it perfectly, as well as had larger jobs taken care of by Top Gear Autoworks - the most reputable place to get a Rover done in the entire midwest.
Aside from everything being perfect, it has also had head gaskets upgraded and replaced, oil pump upgraded and replaced, main crank bearings upgraded and replaced, all done by Top Gear. These are things that are common problems with Rovers, and if you get them upgraded and replaced by Top Gear, they are no longer problems. This is about a $5000 upgrade to this vehicle that will make it much more reliable than a Rover without these services done.
This truck has two sets of wheels with it. Both are stock 18" wheels, one set has the OEM summer tires, one set has Firestone Winterforce tires on it. This is about a $1000 value in extras, and makes the truck handle better in winter, and not wear out the expensive snow tires in the summer.
Truck has a fresh Mobil 1 Synthetic oil change ($80 value) done by Top Gear as well.
As you can tell, this truck was taken very good care of, and has been maintained perfectly. There is no rust, no dents (has one small door ding on drivers side).
Come check it out in South Minneapolis. Email first, then I can call you and we can set up an appt.
