Why not just run the factory cover with the Carli bash guard?
There is no evidence to suggest that a larger cover helps improve anything.
Gale banks recently did a video on it and is currently researching data to see if larger covers actually help.
Yea, definitely found that out the hard way
Has anyone found a decent diff cover that fits with the 11.8 gears, clears the sway bar, and will not make contact with the rear trackbar at full bump? Preferably with a drain plug...
The rear should be a 11.5 not a 11.8, Just have to make sure if you have the rear sway bar there is clearance for the sway bar on the cover.
If you move to 4.30 gears your 11.5 BECOMES an 11.8 as that is the only ring gear diameter that ratio comes in. Just FYI.
Nitro ring gear for the 4:30 gears is 11.8 not 11.5, it fits in both axles. If you run any other gear sets they are 11.5,if you have an 11.8 ring gear and run 11.5 gears you convert it down to 11.5. The 11.8 rear axle runs 300 mm shafts also.That I did not know, I only found like 2 manufactures that even make 4.30 gears for the AAM 11.5 lol.
No pictures for this update, but just got 4.30's put in. Really woke the truck up.
Fun Fact: the rear AEV cover doesn't fit with 4.30's![]()
