2024 Casita 17' Spirit Deluxe
Tex68w
Beach Bum
I guess I’ll have to disagree based on the trailers I’ve seen. I don’t believe there’s any way a glass tub like an Oliver or Casita would stand up to the kind of abuse that a Boreas/Mission Overland/Arkto/Bruder type steel/composite construction could handle. There have been a few fiberglass shell off-roaders, but yhe majority of builders use the tried and true frame and panel structure for a reason. Our trailer could roll and survive. Doubt an Oliver or Casita could.
LOL. We will definitely have to disagree. I suggest you do your own research and educate yourself on the differences in design, material, and engineering of said designs. And if you're rolling your trailer you have a lot bigger problems than worrying about whether or not it survives said roll-over and I'll argue that aside from the frame, it will not survive without major structural integrity issues which makes it a total loss in the eyes of your insurance. But we can argue until we are blue in the face, it doesn't matter because you are set in your beliefs, flawed as they may be. At the end of the day FGRV's are not for you and that's ok.
Photomike
White Turtle Adventures & Photography
I don't have a personal stake in this debate, but I can speak from my experience with my Northern Lite truck camper, which had a fiberglass body.
This whole argument reminds me of something I often encounter at work. I own a photo lab where we offer both wooden and composite (plastic) frames. The composite frames are much more affordable, but every so often, someone will come in and say they're worthless. They'll claim that if a composite frame falls off the wall, it'll break, while a wooden frame will just bend. The reality is, both types are broken—they’re just damaged in different ways.
I'm sure a trailer could be built to be nearly indestructible, able to withstand rolling over without much damage. But once you factor in everything inside the trailer—items getting ripped from walls and tossed around—you’re still left with damage, just of a different kind.
mep1811
Gentleman Adventurer
Nothing too crazy or exciting here, just a commercial built fiberglass RV but since I plan to mod it a tad and use it to boon dock while on motorcycle trips and some hunting trips, I figured I'd start a build thread. We picked it up brand new, direct from the factory in Rice, TX (about 45 mins south of Dallas on I45) the third week of February. It's a 2024 Spirt Deluxe, deluxe means it has a wet bath. We opted for every single option short of their new gray wall material and the lower exterior gray gel coat. Being that this started as someone else's order we ended up getting a decent discount versus placing our own order (for literally the same thing) and waiting another 4-6 months for more money.
The Spirit model allows for a 4-seat dinette that turns into a Full/Queen bed (likely how we will have it setup full time) and a side 2-seat dinette than can convert into a single bed should you need to sleep an added guest. It has a kitchen with a two burner gas stove, deep kitchen sink and the microwave/oven cabinet is wired should we ever desire one. Odds are a simple toaster or possibly a toaster oven/air fryer is all it'll ever see as I plan to use that space as the pantry while on extended trips.
Highlight options include a Coleman Mach 8 Plus AC w/heat strip, Suburban furnace, Fiamma F45 awning, Group 31 AGM 100Ah deep cycle battery, Power MaxxFan, electric tongue jack and an outside shower.
On the sales side of things they were a pleasure to work with, our salesman was quick to respond to all emails and calls and come delivery day he provided excellent customer service. My only word of advice here, go over everything with a fine tooth comb before you pull away as make ready and the service delivery team definitely didn't do as good of a job as the sales team. No huge issues, but there were a few small things they should have caught prior to it leaving, that goes for myself as well.
(Picking her up from the factory)
It'll be nice to have a proper shower and toilet while camping for once.
The full kitchen is a nice touch but we have no plans to cook inside very often if at all. Casita recently moved to a low profile, charcoal filter, ventless style hood. This eliminates another entry point for unwanted critters and cleans up the outside of the trailer as it now has one less vent.
Upon getting her home I removed all of the decals for a cleaner look at my wife's request.
Last week I took it to Houston to have the Katy's Closet with LED light installed in the front closet. I did this for better organization and as a small mod for my wife's benefit as I have to do a few things for her along the way if I want her to be happy with this venture as well. They have a really smart design that maximizes the usability of the space and finishes it out nicer than any closet I have seen in a RV trailer. I also had them install a small shelf in the bathroom storage compartment, now it's no longer just a giant water tight cavity with things stacked on top of one another.
My plans at the moment include the Torflex 3" axle lift and 30" BFG KO2's on the factory aluminum wheels and four BAL 7500 lb stabilizer jacks to improve stability and end user serviceability since they are bolted to weld-on plates in more proper locations on the frame. These stabilizer jacks will also eliminate the need for a separate bottle jack to change a flat as they will provide plenty of height and strength to lift the trailer off the ground in the event of a flat. Doug with Casita Works in Bryan, TX will do the install later this week. I also plan to have his receiver hitch installed in the coming months when they come back in stock. The trailer will sit and look similar to this older Casita pictured below.
Aside from having the windows tinted for privacy, better climate control and looks, we plan to use the trailer in this configuration for the remainder of 2024. If we find that the Casita is all we will ever need or desire (I want an Oliver Elite II really badly lol) then I'll likely take the trailer to Texas Customz next spring to have his World's Toughest Casita chassis up-fit installed which will give it a longer frame on one-ton running gear with larger brakes to match the truck along with true suspension and a rail mounted to the tongue to carry the KTM 500 or Honda Trail. This up-fit will also allow me to match the wheels on the truck and I will be able to jump up to a 33" tire as well.
I have an external solar port wired direct to the battery which will allow me to use my 200W solar suitcase to help keep the batteries charging while boon docked. I want to get a few trips under my belt with the 100Ah AGM setup before I jump to lithium but I do plan to eventually make the switch to lithium batteries and dedicated solar panels on the roof. At the moment I have a RedArc smart battery monitor to keep an eye on things and I'll eventually get around to installing the RedArc 1500W inverter as well. I might hold off on that until I make the switch to lithium so that I can have an altogether cleaner and more organized install.
Planned trips for this year include New Mexico this summer and Big Bend in the late fall. I have a few motorcycle trips in the works as well so it'll likely see some use there in Arkansas and possibly Arizona along with random quick weekend trips to the beach and Dallas.
How were the closet shelves mounted to the wall?
eatSleepWoof
Do it for the 'gram
Rolling over is an extreme scenario and a poor indicator of quality IMO.
Much more reasonable is stress on, and resulting separation of joints, studs, cabinetry, etc. from day to day use. There's no argument against the vastly superior fibreglass body in these scenarios. It doesn't matter how well an "overland" trailer's joints are built and sealed, that approach will always come second to NOT HAVING the joints in the first place. Nothing to seal, nothing to service, nothing to leak.
Now, how cabinetry is built is a different story. I do wish more of the fibreglass RV manufacturers took cues from the quality overland trailers in this case. Same with appliances offered/used.
Tex68w
Beach Bum
Casita leaked a new 15’ Camper due to be out in Q1 ‘25. It appears to have a more modern tilt out vinyl window that is factory tinted. I wish the 17’ model had those windows, they are the biggest disappointment on this trailer. Looks like I’ll be taking it in for a $550 window tint job in the coming weeks.
eatSleepWoof
Do it for the 'gram
Tilt-out windows are the bee's knees. Had them on a Hymer GT550 a few years back and they were fantastic. They've long been the industry norm in Europe. Bug screens and proper, black-out blinds are usually part of the window package, too. Windows are typically standard sizes and you may be able to replace your OEM windows with tilt-out ones, if you wanted to.
Tex68w
Beach Bum
I decided to accept the sub-par old school windows and scheduled it to get tinted with Ceramic 3M next week. Beyond improving things thermally and for privacy's sake it'll improve the aesthetics of the trailer as well.
Obsessed2findARuggedHybid
I asked about how these things hold up because it’s not clear that Oliver’s are able to handle much off-road if you read some of the forums, and they are supposedly one of the best of this type. Fiberglass tubs can have their own issues. And maybe most of us aren’t trailering the rubicon every weekend, but the condition of fireroads out west are getting worse and worse due to govt budget cuts and more severe storms, so those gravel roads are going to beat our trailers up more and more. I’m happy to have something built for bear even if it’s overkill as I’ve seen cracked frames and structural failures out in the middle of nowhere and it’s a terrible place to find the limits of a trailer.
I kind of always wondered why almost all off road trailers are not the fiberglass type. I have several clients in the fiberglass industries of hot tubs and piping. It does seem like the structure of the entire body beating down a road may not be as robust as a framed or frp / aluminum walled system. For sure carbon fiber might handle it. Just speculation here.
Tex68w
Beach Bum
I think it’s hilarious that guys think a fiberglass hull of which millions of boats are built can’t handle the rigors of driving down gravel roads at 5-10mph. If you think an aluminum skinned bolted and/or welded together frame will hold up better to any kind of stress then I have some ocean front property in Arizona to sell you.
Ya I was just asking. My guess is that a fiberglass hull has to be 20 times thicker then a trailer side wall. Maybe most off road builders don't use fiberglass because the molds are so expensive. Plus a fiberglass hull does not have to attach to a metal chassis. Yes 5-10 miles and hour off road but add the pot hole slam at 80 mph on the highway getting to the off road to the mix.
YaRiteZ71
