37s and Sway Bar Rubbing – Thoughts?
Regcabguy
Oil eater.
You could always try ditching the sway bar. Easy enough to put back on if you feel you need it and then explore other more expensive options.
Also check out a tire load table. That 12.50 has a higher load rating at 50 psi (3525lbs) than the 13.50 has at 80 psi (3195lbs)
I've felt the D rated sidewalls of the D 12.50's and the E 13.50's. The D's are thinner and more flexible than the E's. 50 psi just doesn't instill much confidence in the tire for me. I have no idea how the manufacturer's can make that claim.
dhuss
