72 IH + ‘85 Alaskan = Questionable Judgment...
Todd780
OverCamper
I just took a close look at the shifter:
I’m gonna have to relearn driving a standard transmission.
9 out of 10 times, I'd probably go from 1st to reverse....
m-l_johnny
That 1st to reverse is good if you need to rock the vehicle forward and back to get unstuck.
But yeah, new habits will need to be learned. I confuse myself going from the JK 6 speed to the CJ with the “4” speed NP435
Nailhead
Unloaded you'll probably start in 2nd anyway.
Still gonna be neat going to 4th then slam forward for 5th/OD.
This truck hasn’t been unloaded since the camper went on it. First gear is mandatory for getting underway.
Nailhead
The Memorial Day push is on:
New seal in the transmission-
Waiting for this one-
Made a jig for removing the nut, though-
Working on the intake manifold finish-
Nailhead
How did you clean the valve covers? Chemical or abrasive? They look great.
Sent from my Pixel 7 Pro using Tapatalk
First pic is the parts cleaner, where I remove greasy dirt. A small wire brush is essential.
I towel & blow it dry, then cover the painted areas with KBS Aircraft Stripper for 30 minutes or more. Then I rinse it, scrubbing off the old paint & stripper residue with both bristle and wire brushes. If necessary, I repeat the process. Any paint that’s left over I figure is more than robust enough to hold new paint, so I move on.
After a thorough rinse, I dunk the piece in Evaporust:
I poured this and another 1 1/2 gallons in a plastic tote, where I leave the piece for several hours to overnight. The result is that bright, bare metal finish you see above. After another thorough rinse, I try & towel dry it as quickly as possible to prevent flash rust, but that really only minimizes it. CRC sells a product to prevent it, but I just wire brush it then give a wash with brake clean. A thorough blow dry, and it’s ready for primer.
YaRiteZ71
