80 or 100
Life_in_4Lo
pskhaat said:
Is this true? Just because one aspect is no longer used doesn't mean it was a mistake, right?
We all have V8s now in the LCs but arguably the straight-6 is a better design; we all have IFS now does that mean a live front axle was a also a mistake from Toyota?
I think there is a large factor of repeatable tooling and process, not necessarily equalling the `best' (subjective) there is to offer.
IFS continues to be used, just not torsion bar IFS. That was never done again by Toyota. The coilover setup is vastly superior and upgrades offer much more improvement than anything that can be done with t-bars.
It's like going from leaf to coils on sfa Land Cruisers. Toyota never went back to leaf spring front axles either.
If the 100 had coilovers, it would be so much more mod-able and make huge improvements, otherwise i really think it's great. Even as is, it's an amazing suv.
The sfa has kept going in Toyota production around the world where needed. In reality, it's just not palatable for the US market spending $60-80K on a luxury vehicle.
SFA, in Toyota's eyes, is just not marketable and makes too many sacrifices on road.
I can see their point I guess, but wish they revived the sfa on the FJCruiser. (But, they reused the 120 platform for it so I guess this is a cost issue. )
Is the I6 a better design? Both the I6 and Solid axle are better in a offroad-specific purpose suv maybe.
For the requirements of frequent road use, lighter offroad duty and passenger comfort & space (the requirements of the 100 and every toyota suv after) the IFS and V8 are better choices. Also, the V8 has more HP/TQ and is a smooth engine.
The I6 is easier to work on in the field but the V8 more compact. The 80 has a long nose and that takes up cabin space. The 100 is more accomidating because of this fundamental difference, not just the increase in dimensions.
Honestly, tho the I6 is a great truck engine, I prefer the V engine just for the extra space. Besides, Toyota's truck engine- the 1GR-FE, a vvti v6, is a wonderful chain driven truck engine though somehow, I think the I6 1FZ is far more robust and they don't do 300,000 mile designs on engines anymore (i dont think). I also think the V8 w/ 5spd is so nice, and the new 200's 5.7...well it's just awesome.
But the 80 is just fundamentally an offroad suv. No compromise- just made to be the best, most luxurious, offroad-focused suv.
Despite arguments, the SFA just rocks. It's just better offroad. Doesn't have to be rockcrawling or tough obstacles. If you're using it offroad day in, day out, year after year, "abuse it and put it away wet" than SFA is it.
Sure it's got tradeoffs- all of them on-road. That doesn't lighten the weaknesses of the 80 (compared to the 100).
mix the two- put a 4.7L/5spd in the 80 or SFA the 100... that takes a lot of the complaints out of both and creates the uber-LC! actually, I'm a big fan of all of Toyota's suv's. I think they are the best engineered.
Life_in_4Lo
spressomon said:
1. 4.10 R&P instead of 4.30 R&P on '98-'02: This along with the 5-speed makes a great 4.88 candidate. Downside is on '00+ you may want to add a rear locker (front ARB should be a given on any 100 that will see off-road use IMO).
The 03+ also has a redesigned interior that is quite nice. The 5 speed tranny is a big plus.
spressomon
jgolden said:
Nice ride,
Why did you switch the tires and wheels? Is your new setup about the same height but a little skinnier?
I wanted to try less wide tires than the 315's I have been using while keeping with 35" tall tires. And I wanted an AT tread with a carcass of an MT (we have LOTS of tire eating rocks on our back country roads out here) which the Toyo Open Country AT in this size provides. And I was tired of fighting the balance issue of the Goodyear MT/R's!
For the majority of the types of terrain I run my rig the 285 width is better. It changes the contact patch: Better handling & cornering on gravel roads & washboard (even though the Toyo AT is an E rated tire and is 15lbs heavier than the 315 width GY MT/R they replaced!). They will be better on snow and ice too. And I was able to eliminate the front wheel spacers: Steering is mucho better now!
I wanted the 285 width, 35" tall on a 16" wheel...but they don't exist (at least in an AT style tread pattern). Toyo started offering this size in their AT and MT earlier this spring.
Pskhaat
2005 Expedition Trophy Champion
Gotta tell you my biggest beef is no manual tranny. I don't do hard-core stuff so I enjoy a manual completely.
I'm also a big fan of overstroked straight-6 designs HOWEVER I gotta give the little 2UZ-FE credit where due: it's a great engine. Not as good (not trying to repeat myself) as I feel the various F-series', but very smooth and doesn't burn a lick of oil after a year.
Too bad there won't be a 2FZ-FE.
Life_in_4Lo
I actually like the auto tranny for offroading- just easier. Maybe i'm just lazy
I'm sure the manual is more efficient and you don't loose as much power
I do enjoy the manual tranny on the street tho :smiley_drive:
On the power- since the 1FZ superchargers are available again, it's become really tempting to boost it and get rid of any deficiencies!:rally_guys:
calamaridog
IFS "failures", or more specifically stress cracks related to the torsion bars, were only a problem on on diesel models.
The torsion bar design on the 100 series is very robust. They are the biggest torsion bars on any production vehicle. There is nothing "wrong" with the design, per se. The steering rack is a little weak, but again, the unit is larger than the one used on the first generation Tundra.
Would I have prefered a coil over shock design on the 100 series? Sure I would, it would be easier to "upgrade" with bling and the ride is better... The new model LC addressed this issue.
Anyone who is interested in maximizing their 100 series suspension needs to look closely at Dan's set-up...
jgolden
OK, I'm convinced.....
I'm on the lookout for a 2003-2005 Land Cruiser. What are some "options" I should look for in this era of vehicle? Also, the prices are all over the board....I've seen them range from 19K - 49K????
thanks
jg
Pskhaat
They seem to go down almost linearly with mileage. An 03+ at $19k is a steal IMO.
Don't discount the 98-02s either though. ``In the family'' we've collectively owned 4 LC100s. A 1999, 2000, 2005 & 2006; I've driven them all extensively (okay the 2006 only on the street :) ). Anyway, I will say that I have no particular affinity towards the latter years. They do indeed have a noticable power punch later in the band (you can tell the breathing is better with the variable valving) that the earlier models do not, but genuinely it's on the fun pedal and I've never had the need in our 1999 off- or on-road. The transmission gears and ECU shift points are matched nicely with each small change in the 2UZ-FE over the years.
I am currently seeking a 2001 however only for the LATCH option but don't want to give up my factory locker in the 1999 despite how great ATRAC is in the locker's stead.
DaveInDenver
Middle Income Semi-Redneck
AndrewP said:
No one said IFS can't go through the Rubicon, I've seen it done plenty of times, including by a 100 series. It's more a matter of when things go wrong. It is generally easier to fix a solid axle truck than an IFS truck, and the SFA is less likely to break in the first place, Chris H's notwithstanding!
If you just want a wheeler, nothing compares to a SFA minitruck.
Good job, by the way.
Yeah, I was just being factious. It's funny, though, for all the worry I had about ball joints and IFS trusses and skid plates, the part that I did break was a normally reliable leaf spring in the back. Funny how irony goes, eh?
http://risingsun4x4club.org/forum2/showthread.php?t=7757
If I was a real rock hound, no argument that live axles front and rear would be more reliable over the long term. But I like to fool myself that a careful right foot and keeping things within limitation on tire size and stuff are more important to the longevity of IFS than anything. Plus, as if IFS wasn't enough, add 122" wheelbase and a WilderNest, now that's just plain stupid.
jgolden
Thanks for the info. What is the LATCH option?
What are some options I should look for in the 2003+ years?
What year did they come out with airbags in the rear of the vehicle? I have a young son and #2 on the way
spressomon
What's the "LATCH" option? I'm thinking one of these years when the '07's get down to my level of affordability it'd make a nice modded overland rig. 4.88's in an '03+ would be just a little better, especially coupled with the 5-speed, when I'm pulling the AT up some of the steep climbs I seem to find off-road. And the VVT would be a nice bonus.
iStan814
