Prescott
Prescott, are you putting the DOHC heads off the 96 with hole in block, onto the good SOHC engine you sourced? If so that might be the way to go. The wiring harness and routing looks quite a bit different between the DOHC and the SOHC. Really I should say routing. I think that was mentioned earlier. I have a 95SR parts car and a gen 2.5. The connectors look mostly the same but the routing of the harness is pretty different. Getting that to fit might be a tough job.
Yep the DOHC heads are going on the SOHC motor. From everything I have read it the same block and the heads im getting are the same ones that are already in my montero so there should be no problems what so ever. Getting excited. Hopefully within the next 2 weeks I will have this going and can get out to meet some people.
