AA1PR's M416 Trailer Build Thread..
AA1PR
Disabled Explorer
the challenge was finding one the right size of 75.5" X 58
& here is ours strapped down for transport home
the guy I bought this trailer off of had a commercial box of the back on it hence the flat stock welded around the 3 sides/edges with preexisting holes
this one is 75.5"X61" so I have some overhang, but oh well
it was a simple place on top, even out, drill holes up through flat stock existing holes & tighten down nuts & bolts
however I added some 1/8" rubber strips under the cap edge to provide some sort of a seal
here are the finished results, not perfect but not too bad, just need to replace that rear window now
AA1PR
Disabled Explorer
In the trailers for sale section of the forum there is a camper top that fits a 416 trailer. If nothing else the photo in the ad may give you an idea of what yours could look like. (Not my ad no relation)
thanks
I have debated what look or way to go with this
since I will never off road with this I thinking this is our route for now
AA1PR
Disabled Explorer
thinking of the camper idea a bit more today & I thought of this...
I'm going to build a raised floor with some of the left over 3/4 plywood at least 6-8" off the metal floor
this will be either carpeted or layered in foam like these from when I had my home gym [still have a lot of this in my storage locker collecting dust]
I'll cut them to fit
underneath will then allow me room to place our camping chairs, table, tent poles etc while still allowing enough head room
just an idea since I feel like changing the original scheme of things
AA1PR
Disabled Explorer
AA1PR... don't forget I got tire's and wheel's for ya...looking good!!
Yes & I have those dodge rims for you too
maybe if we go camping this weekend I'll catch up with you, since it might be up that way possibly
thanks, its a work in progress & not sure where I honestly want to go with it
so for now I like the camper idea for my girls
AA1PR
Disabled Explorer
dragged the M416 along to sleep in
however the twin air mattress I purchased was a joke, it couldnt hold air for 10 minutes
at camp
left the landing leg down to keep some bounce out of trailer
got the led lights installed too
need to redo the rims I noticed
sitting pretty in our campsite by the pond
AA1PR
Disabled Explorer
camping in it this past weekend
& snapshots over its lifetime since I have owned it
AA1PR
Disabled Explorer
not sold on the truck cap I placed on it
might look or think about building a better lid for it before the summers over if I can
AA1PR
Disabled Explorer
if the weather remains nice this weekend I'm fixing that broken rear window on the cap with this ~ http://www.homedepot.com/p/Unbranded-1-4.../100092485
I'm going to stain & clear coat it, I want that old fashioned wood appeal
& then thinking of maybe some insulation for the cap as well, though I need to measure the posts of the cap first
like this~ http://www.homedepot.com/p/Frost-King-E-.../100028603
& some of this for around my rear door ~ http://www.homedepot.com/p/MD-Building-P.../100353450
& if time allows making a raised platform for the air mattress or maybe a real one
keep your fingers crossed for me
AA1PR
Disabled Explorer
with the help of my 2 girls & my father, here's my results for today
went to homedepot & got our 1/4" cabinet grade birch, 2 - 1/4"x3/4" bolts & nuts, cherry stain & laquer
started off by taking the bottom window portion off, drilling out the 2 rivets that were holding it on
then we added our eye bolts which will be attachment points for our DIY awning
decided the awning should be over the back, but might also add ones for side mounting as well
with the help of my oldest daughter we got the piece cut to shape, & she proceeded to do the staining
noticed once I removed the factory rubber seal the groove here was deeper than I had thought
so I tried to fill it up with a layer of silicone (once hard I thought), though the tube said it was supposed to be clear it was white...20 miles too far to bring it back...
here is our piece all installed & looking pretty
started on the frame for our raised bed platform, & decided to also have a sort of secret hidden access panel at the top
used the old 3/4" plywood I have left over from my top I removed back in the spring
got both sections installed, after my dad crawled in there to do a test sleep we noticed that the 3/4' plywood was flexing so I added a short 6" piece of 2x6 in the center of the bottom section
two finger holes are drilled in the top section so you have grab points for lifting it out
also we cut back the door edge so it made life easier trying to add or remove stuff from under there
my back was killing & I was ready to call it quits & my dad came up with the idea for a side area to store fishing poles, tent poles etc that now wouldnt fit underneath anymore
its secured on the ends of the trailer & the inside lips
just as we finished this the thunder & lightning came rolling on in & we lost power
CharlieGreenT
