Another-nother OVRLND camper build
bgraboyes
Truck: 2019 F150 SCREW 6.5' Bed 3.5L ecoboost, XLT, FX4 - stock (other than K&N engine filter - ha)
Camper: Camp OVRLND popup
I should have taken more pics along the way but will try to document at least some of what has been done and can probably answer most questions and take more pics if anyone needs help with their own builds. I go a lot of inspiration from @crolison and his 2 ovrlnd builds and wanted to try and pass on some more inspiration/information.
bgraboyes
So the first issue that i had to tackle was dust intrusion. F-150 tailgate is the hardest damn thing to seal in the world. I tried the rockblok, miles of bulb seal and every other option i could think of to keep the tailgate but to no avail. i also decided that it would probably be easier to open and close full barn doors from the inside rather than a tailgate. Eventually got Jay at ovrlnd to construct some barn door extensions, got em installed and then built out a metal frame using 1/2"x1" aluminum tube that i riveted to some 1" aluminum angle. I attached it to the truck with some 1" VHB tape then caulked the heck out of it and put on some more bulb seal. The result has been near complete fix of the dust issue. All of the truck caps type campers I assume will have the same issue on an f150, don't really think it was an OVRLND problem at all, just a very porous f150 bed and tailgate! I can get more pics of this if anyone wants. also please excuse the ugly caulk job, not my forte but it works.
bgraboyes
The solar was originally wired to passenger rear side. My build plan was to put the battery in the bed on the driver side so i re-wired the solar to that location, wires actually fit really nicely between the composite floor of the cabover and the aluminum frame
bgraboyes
Due to the tailgate delete I was going to lose the backup camera. Instead of spending $100 or more on a camera, i just took the tailgate apart, separated the camera wire from the lock mechanism and then re-routed the camera and attached to the center of the license plate w/some velcro and one wire clamp as seen. works pretty well but i need to come up with some way to shield the camera from the license plate lights at night as the glare messes up the image.
bgraboyes
i installed a baseplate of 1/2" plywood. forgot to take pics but i put down 1/2" rigid foam insulation to fill the valleys between the truck bed ridges, glued it to the bottom of the plywood to keep it in place. mostly did this to have a place to screw a few things down to and get a little insulation. I had already measured out where to put my drawer so i put 8 pre-placed tnuts on each side where i would later attach angle brackets to hold the sides in place. Second pic shows drawer frame in place. I made my drawers with the much written about skateboard bearings and 1" square tube. Many people have better write-ups on this but it's a great way to save $2-300 on drawer slides
Crowboy
I'm really enjoying watching your build come together. One of the great things about OVRLND and similar campers is that it allows you to customize to your needs. I've got one on order, but now the wait is on.
bgraboyes
it's definitely worth the wait. fun project for sure and lot's of learning along the way.
How tall are the drawers you installed? I will be picking up my OVRLD form Jay later this month, and building a set of drawers would be great for additional storage, but I figured if I did that I would no longer be able to stand up straight in the truck bed.
bgraboyes
top of the deck is 10" from the bed. usable drawer space is 8" tall. I still have right about 6'2" of standing room but i think that's dependent on your truck (bed height) and camper bedding height. I got the extra 2" of bedding height in the cabover on my ovrlnd build which gives you an extra 2" of standing room as well. hope that all makes sense. the deck above my drawers rests on the wheel wells to make the build easier.
Thanks or the info. I will just have to see how much headroom I have once I get it on the truck late this month. I also got the additional space for bedding, so maybe I will be able to get a set of drawers in there as well.
SDDiver5
Nice work! I love OVLRND campers. If I ever went that route, I'd def get one from them with full barn doors.
bgraboyes
it's been a while and a lot has been done. I am not the best at taking pics at every stage so if anyone has questions, feel free to ask.
solar panel has been up for a while. was a pretty easy instal with some angle brackets w/predrilled 3/8" holes that fit the L-track bolts perfectly. just had to drill into the frame of the solar panel to attache to the brackets.
bgraboyes
Installed the propex heater in the passenger front side of the bed. most nerve wracking part of the whole build was drilling the large holes for combustion intake and exhaust. Make sure to check under the truck to ensure you aren't going to hit anything important. i routed the exhaust out to the side so you don't get any rising combustion exhaust into the camper and the intake i routed up between the wheel well and bed. copper line runs from inside all the way back to a quick disconnect
WonaWarrior
