antmax26
I had been looking at other m416 builds and ran across a build by "wompser" on another forum. He had built a table that attached to the side of the trailer. I had to make one. I ran to the local wood store picked up a 2 X 4 sheet of 3/4 in plywood. Also bought aluminum C channel to run around the edges and a can of Thompsons water seal. The idea was to bevel the back edge that fits against the trailer and hold the table with adjustable hook and eye brackets all supported by the fender. I made cut outs of the table for the bolt on top of the fender and also for the trailer tie downs. After I made it for one side I tried it on the other just to see and it did not fit. It was a easy fix as I just needed to adjust as one of the tie downs was at a different angle and I just needed to shave down some of the wood in One of the cut outs. I now can place the table on either side. I treated the table with the water seal and ran the C channel around and it has turned out to be a very nice and stable table.
Credit to the origional idea.
http://forum.ih8mud.com/trailer-tech/319054-wompsers-m416-trailer-build.html
