Anybody doing an LR3 as an off-road rig?
Update:
Thanks everyone for all of your responses! I should have an '08 HSE with 24,00 miles and a rod lift / tires by the end of the week! I also ordered a Fault Mate MSV-2, and the truck should be coming together shortly!
Dave, you're killin' me here! ;)
Once it warms up we'll get out to play :sombrero:
KAA
nwoods
Update:
My last inquiry (for now!)- What is everyone using for sliders and underbody protection? I DEFINITELY want to do a set of sliders, and from what I gather protection for the exhaust and fuel tank is a good idea as well. There has also been talk about relocating the lines running up the inner front wheel well for the computer equipment so that it does not get snagged by an oversized tire that is stuffed in the wheel well while off roading-any ideas on that? Pictures, if anyone has them would be great!
Thanks again, everyone, for making this decision a little easier. I cannot wait to get my hands on the truck and see what it can do!
Thanks again!
Congrat's on your purchase!
I have a long history with the Rover Specialties sliders, and highly recommend them. The only question is what profile to get. I would suggest the Option 2 Slim's, or Option 1 without the standoff tubes. It depends on the nature of your obstacles. If lots of trees, stumps, roots, etc... then the standoff's are probably a good idea. For very rocky areas, like here in the southwestern desert areas, I like the Option 1's without the standoffs. You need to drive a bit more carefully, but you won't be snagged on rocks nearly as much as with the outriggers. The LR3 has more clearance directly under the wheels, and with it's phenomenal traction control, the best line through an obstacle is typically with your wheels on the largest rocks. This puts your rockers in harms way, and is why the RS sliders offer such great protection with their unique design.
I also really like the Rasta underbody skid plates, though the Mantec front plate is also very good, but its only the front plate, whereas Rasta offers the whole system. Asifr makes a bunch of stuff also, but I have not kept up with it lately so my info is out of date.
As for the refrigerant line modification, yes with the HSE it is something you should consider if you are going taller than 31.5" tire diameter. As I have suggested a few times, that information is on LRRforums.com. There isn't a whole lot of info on ExPo related to the LR3.
tacomadave
Wow! 7 pages and not one post about how the lower control arms are going to fall off, or the electronics will leave you stranded, or any of the other typical bs. :coffeedrink:
I own a JK unlimited, and my father owns a LR3, i've spent a lot of time in both, and I like them equally. Only real issue we've had is lack of good tire availability, we put Wrangler Silent Armours on, and have had a few flats and one sidewall tear that required replacing the tire completely.
Dave Legacy
I'm pretty sure that NWoods already mentioned the control arm issues and a few people have mentioned the electronics risk. IIRC the control arm bolt sheering off was a pretty isolated incident, right? Was this the case where bushings were replaced, but the original carriage bolt was reused?
Sleeping Dog
The testing has begun. . .
When I saw Graham's article in the recent OJ, I hoped that he brought an LR4 home for extended testing.
Jim
nwoods
Lr4 is miles ahead of the lr3.well worth a little more cash.
I'd like to know more about why you feel this way. I don't really doubt it. But on the surface, it certainly seems even more of a softroader than the LR3 does. Painted shiny parts, less dust and abuse tolerant interior, etc.... Same basic suspension and electronic systems, just better visibility (a gazillion cameras), and possibly too much horsepower.
nwoods
Good choice on the Faultmate. I think if more people factored these things into the price of the car (or if the OEM's included this functionality in the touchscreen...) it would go a long way to dispelling the "but the electronics are too complicated" myth from the traditionalists. But I'm biased. My current day job largely involves removing prime movers and lineshafts from old industrial equipment and installing multi variable-speed AC drives, and programming HMI's.
Nathan, SCCA SS, which car(s)?
Paladin, I was just searching for this thread to link to another discussion and saw your question about SSCA. I raced in Pontiac Fiero's (`87 and 88). I was very young and the team manager liked me, but when the 4wd turbo Eagle Talon came out, we became immediately non-competitive and I was "let go". I didn't travel, only participated in local races, but man I had fun.
MattScott
Approved Vendor
From when I worked with LRU I believe it was pretty much just a slight redesign of the air suspension system. They went to a more reliable air compressor, and moved the air lines to a safer location. I found the LR4 to be easier to drive off-road than the LR3, it seems the vehicle is more 'aware' of what you're doing, which is pretty important when you're taking a computer off roading.
REDROVER
Yes, my JK is an Unlimited Rubicon, loaded with all kinds of extra goodies.
The LR3 has some impressive electronics that take care of a lot of the off-roading details. As was mentioned above, it really makes it all too easy.
WOW WOW WOW DID U SAY LR3 IS BETTER OFFROAD THEN RUBICON? HUH??????????????????????????????????????????? U DREAMING BROTHER ?
flipstick
