mhiscox
DUH.Mike I have never seen it set up for two sleeping. Any chance of that shot? Thanks. Ken
Yep, that would be important, wouldn't it, since it never got shown in any of the other posts. Here goes . . . (though please excuse the zany white balance; didn't seem worth fixing for the purpose) . . .
This is what the sofa/mattress cushion (removed for clarity) rests on:
But when you lift up the hinged-at-the-rear platform, you see the movable (second) sleeping platform comprised of an inflatable camping mat about 2" thick,
and yet another Paul Jensen trick carbon-fiber-reinforced thin plywood board that, in spite of its size, just weighs a few pounds.
A Walmart yoga mat was affixed to the back of the platform to eliminate the potential for scratching things up and to provide a grippier surface. Seems to work.
You deploy the board over the freezer and countertop, which provides much sturdiness. But the part where your feet go is unsupported, which works because your feet are relatively light. You could not sleep with your head at the front of the truck.
If I wasn't taking explanatory photos, I would have moved the platform and pad together. In any event, you end up with this.
The last piece of the puzzle is a Therm-a-rest sleeping blanket, which is about 70% of a sleeping bag. It's not joined together longitudinally and, very usefully, has an elasticized footbox that you put around the base of the sleeping pad (or in this case, pad and platform) and it holds the bag in place and keeps your feet from poking out. This is the same setup as I use in the XV-JP and I think it's the best alternative for sleeping inside something that won't get really cold, but won't be kept house-level-warm, either.
It works pretty well. Paul, much bigger than I am, demoed it for me by lying on it and turning every which way. The platform didn't move in any direction, nor did the unsupported foot section bend.
BTW, from the Land of Pleasant Surprises, I've discovered that, what with Paul's narrow cabinets and the innovative "toe kick" area under the front bed, there's enough space to plop down another full-width/length sleeping pad on the floor, opening up the possibility of sleeping three in relative comfort, though the people on the platforms would need to exercise very substantial care when exiting their beds.
